Question about Spectroniq PDV-70X
Video game monitor
How do i use my 70x as a screen for video games?????????????
Anonymous
You can not , it only send video and audio to external souce , it does not have video audio in jacks
Posted on Aug 19, 2009
Game is working, but no color..screen is black and white
If this is a game which feeds a television monitor, the first thing to check is the cables between the game and the television or monitor. Likely there is a mismatch of cabling. The jacks from the game are not the same type of jacks at the monitor. If the game feeds composite video down one cable and it is plugged into the jack which accepts component video, the cables for the color are Pb and Pr or similar lettering.The monitor is looking for color information and is not receiving it from the game. Check the cables at each end to make sure there is a match in the outputs of the game to the inputs of the monitor.
Aug 04, 2011 | LeapFrog Clickstart My First Computer Pink...
Screen turns black when tring to play video games
update the display adapter and check with the requirements for the game
if required upgrade the video card
Mar 13, 2010 | Gateway FPD1975W 19" LCD Monitor
SCREEN turning to black and wont stop?
How old is your monitor? If it's an LCD type with 5 to 9 years of age then it may have burned out lighting inside of it. You would just replace the monitor. Check the back of the monitor for the date. If 2004 or earlier then you need a new monitor. You did say the video comes up to desktop, so it's not the video card, and the pc booted up so it's not the cpu either. I've had this problem too.
May 23, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Black screen when starting a game
check for the video card speed requirement of your game. it might be too high for your video cards, a 256MB video card could not display a game with 512MB video card speed requirement.
May 20, 2009 | Acer V193w LCD Monitor
Monitor screen goes blue after game install.
You have an incompatability between the drivers and Windows. Uninstall the games. Is everything all right now? Upgade your video and sound drivers. You can download these from the manufacturers web site. Now reinstall the games.
Mar 21, 2009 | HP w2207 Monitor
Monitor out of range when a game is booted up
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Jul 29, 2008 | Compaq MV 540 15" CRT Monitor
Display moves when in games
This is because your game is changing your video mode and timing. Check in the game's settings, see if there is a "use default video mode" option or if you can specify the 1440X900 mode manually.
Jul 10, 2008 | Acer X193W LCD Monitor
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Wavy lines, goes black during video games.
It sounds to me like the monitor's refresh rate is too low to support your current settings, and the demands of the game. Have you tried adjusting the refresh rate? If I'm right, you should be able to fix the wavy lines that way. I'm not sure how much control over the refresh rate the game takes, but if you can fix the wavy lines and the game still doesn't work, I think you're not likely to get the game to work on this monitor.
Aug 28, 2007 | Proview PL926WBi 19" LCD Monitor
Spectroniq PDV-70X Logo
Top Spectroniq Televison & Video Experts
Charles Tidwell
Al Ursich
Level 1 Expert
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
