Televison & Video Logo
Akai rc 0093N
Hii.. my akai ct-t21n32s crt tv in child lock.. please tell me..how to do unlock akai ct-t21n32s tv...?PLEASE HELP ME.... WHAT IS CHILD UNLOCK CODE..?
Posted by NIPUN SARANGA on
    Top Expert:
  • Televison & ... Master
  • 76,851 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Unlock procedure to many popular brand TVs are given.
Posted on Feb 05, 2014
5 Related Answers
Gigatech
Rafael Ortiz
  • 259 Answers
SOURCE: HELP ME PLEASE......................
Try this:
You need to hold down the tv/av and the power button down together for about 5 seconds
Hope this helps. :}
Posted on Apr 02, 2008
Anonymous
  • 2712 Answers
SOURCE: child lock on tv
All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Posted on May 24, 2008
andy4254
andy williard
  • 226 Answers
SOURCE: child lock
you will need your original remote control and go through the menu to unlock it. find your original remote control by typing in your TV model number in the search on www.replacementremotes.com and your original remote will pop right up. very easy to use.
Posted on Jun 11, 2008
Anonymous
  • 458 Answers
SOURCE: tv lock turned on and can not unlock
need tv model or you try 0000 or 9999 or 7777
may be ok .
Posted on Sep 04, 2009
Anonymous
  • 863 Answers
SOURCE: cant unlock child lock on dvd player
Some require you to put in a code so your kids don't fu.k with it and turn it off.  Check your manual.
Posted on Oct 30, 2009
1helpful
1helpful
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to : http://www.akaiusa.com/
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
1helpful
Child lock please unlock appeared in the TV screen
my akai tv child lock,model CT-14BM MK ,How do i unlock please.
I have a problem with akai 29" old model
U have to know the actual codes.Could be any things.Tries their website get their tech. line.They'll tell u how to reset the thing.
21helpful
2answers
How to undo Child Lock
the key "POWER" +"TV/AV",
1helpful
CHILD LOCK
for the password type in all zeros unless youhave already set it then u must acess the service menu and reset everyting within there. how to access the service menu- power off, mute-1-8-2-power. if that code doesnt work let me know we can try another one
19helpful
5answers
AKAI TV UNLOCK
i have nec 42" lcd tv have lost remote and cant do anything as child lock is on can only turn of at mains can anyone please help to unlock?
3helpful
Child lock in akai CT-T34NE2S
press togother 2 knobs AV/tv &power
14helpful
4answers
Child lock
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
Open Questions:
Top Televison & Video Experts
Marvin
Marvin
