Question about Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player
Alpine CDE 148 BT doesn't reconize my iPOD - Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player
5 Related Answers
simplemitch
Mitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
Anonymous
  • 82 Answers
SOURCE: hooking up alpine hd radio unit, bt-400, which one do i hook ipod to
Niether .... do you know what you have in hand? Both those extras costed someone some cash ... OK here it is: the CDA-9884 has a dedicated input for ipod (a KCE-422i cable is needed and comes with the new CDA-9884 in the box) ... The HD radio unit allows you to recieve new HD radio signals (digital radio, and stations that have it in your area may also have extra music streams like HD TV does). The bt-400 is a bluetooth adapter to use bluetooth enabled devices with such as a cell phone. If your ipod has bluetooth you could used the bt adapter but I suggest the KCE-422i cable instead, and check out the HD radio too, it's pretty cool.
Posted on Apr 17, 2009
Anonymous
  • 655 Answers
SOURCE: Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Posted on Sep 23, 2009
Anonymous
  • 655 Answers
SOURCE: i am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Posted on Sep 25, 2009
Anonymous
SOURCE: Alpine - 50W x 4 In-Dash CD Deck Model: CDE-100 |
You have to run it through the aux input, the usb port will not play an ipod through it as it doesn't have the ipod 2.0 software on it, you can get a ipod connector that plugs into the back of the head unit, and then plugs into your ipod and you can control it from that as well as charge it, but other than that you have to use the aux input. The only thing you can play through the usb port is music on a thumb drive.
Posted on Dec 19, 2009
I have an Alpine CDE-SXM145BT car stereo. that will not play Bluetooth devices.
Have you had the battery removed at any time before this happened or been jump started ?
Apr 09, 2017 | Alpine Car Audio & Video
Is there an adapter I can purchase to be able to play an IPOD with my alpine cde 9841 car cd receiver stereo?
Your headunit doesn't have the option of a plug i Ipod cable, The only way to use it with your stereo is to get an FM Transmitter and you tune into the ipod through the radio.
Mar 06, 2012 | Alpine CDE-9841 CD Player
Hi have just baught an alpine cde 103 bt and the multi changer plug is different to the din lead connecte on my changer ? can i get an adaptor adn where from thanks nick
sorry, the cde 103 will not operate a changer. changers are pretty much on the way out and very few new radios will operate a changer. most are set up to operate mp3's and ipod's.
Jan 31, 2011 | Alpine CDA-9852 CD Player
What do i need to do to play my 2nd generation ipod touch through my alpine CDE-103BT
need to buy the alpine ipod adapter go to alpine site see who your local shop is and go buy cable
Dec 23, 2010 | Alpine CDE103BT CD Reciever iPod and USB...
Where do you plug mp3 or ipod connections
Unfortunately your deck does not have any ports for ipod or mp3 players. If you would like to connect such items you need to upgrade. Here is the link that has your deck specifications
http://www.crutchfield.com/p_500CDE9843/Alpine-CDE-9843.html?search=Alpine+CDE9843&tp=5684&tab=features_and_specs
I am not a fan of CDE line, you are better off with CDA line.
Sep 19, 2010 | Alpine CDE-9843 CD Player
How do I get the clock to stay on, on the Alpine cde-102?
I also have the same question, can any one help? How do I get the clock to stay on, on the Alpine cde-102?
The moment you switch off the system the clock goes off, even if the car is running.
Jul 03, 2010 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Play ipod through alpine cde-7858
Most simple way is use an FM-transmitter
I use a Griffin i-trip smartscan, it is VERY good.
Ebay £30 - 40 for the good ones but even the cheaper ones work well.
Jan 06, 2010 | Alpine CDE-7858 CD Player
Alpine CDE-7858 external input?
yes there is an adapter cable made for this search alpine aux adapter on ebay they run aprox $30 it will plug into cable on back and give you 2 rca inputs to use for ipod and such...
Nov 23, 2008 | Alpine CDE-7858 CD Player
Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
