Air bag blinking all time how do reset?/
Hi Robert
do this procedure and your Nissan will be OK
switch ignition ON till airbag light goes OFF briefly ( approx. 7 sec) immediately after light goes out turn ignition OFF for 3 sec,
repeat this 3 times, after you switch ignition OFF 3rd time for 3 sec
switch ignition ON for 1 sec then OFF, again switch ignition on and start the car, the AIR BAG light will goes OFF.
let me know how it goes
good luck
SOURCE: 1994 crown vic air bag warning light blinks
it is a code,does the horn and cruise still work?chances are the clock spring wore out and broke,its behind the steering wheel and about $100.00 part at Ford
SOURCE: AIR BAG LIGHT BLINKING
THAT IS A CODE 44 RIGHT FRONT PRIMARY AIR BAG SENSOR TO PRPERLY MOUNTED TO VEHICLE
SOURCE: air bag light is blinking
my airbag light is blinking . can i reset anything its a04 nissaun armada
SOURCE: Air bag light blinks 4 times then pauses then 4
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
