Question about KitchenAid Dishwashers
KUDP01ILBL6 The handle was broken, it was still working somehow, but since last week it stop working. The lights were up on the panel. I can select normal wash then that light is on, but cancel light is blinking all the time. I ordered the handle part and replace the broken one, but no change not he front display. the cancel light still blinking....
Posted by shyboy67362 on
  • 3 more comments
  • shyboy67362
    shyboy67362 Feb 04, 2014
    Pressing start is not starting the dishwasher, all the other buttons seems to be working except the start button.
  • shyboy67362
    https://imagizer.imageshack.us/v2/2750x1...
  • shyboy67362
    These are the buttons that I have, does not have sanitize and heat button, so what would be the seq?
  • shyboy67362
    These are the instructions, which I guess means that the switch is bad? but not surehttp://imageshack.us/a/img837/3204/c64n....
  • shyboy67362
    This is the main control board.http://imageshack.us/a/img547/7674/ukc5....
RonW
    Scholar:
    New Friend:
  • 111 Answers
Technical sheet say you have a stuck key on the keypad
Posted on Feb 06, 2014
Testimonial: "no."
  • 1 more comment
  • shyboy67362
    shyboy67362 Feb 06, 2014
    Stuck key on the keypad? how do I reset it? I shut down the circuit breaking for 2 days just to see if that reset,but no help.
  • RonW
    RonW Feb 06, 2014
    Per tech sheet for this model will not start or run and above key(s) is flashing rapidly stuck key(s) or shorted circuit (s) on keypad in keypad, shorted connections or circuits on control panel that read the keys this tech sheet should be attatched to the panel under dishwasher door
  • RonW
    RonW Feb 06, 2014
    Sorry there is no reset
3 Related Answers
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
Anonymous
  • 3 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
Jrussell789
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
I have uh30010 hoover that stops and flashes when handle tilted
I had one in doing this last week. I replaced the upper handle and it acted normally again. Maybe just a bad connection where the handle plugs in?
This is the part I'm speaking of:
http://www.vacuummedic.com/product.php?id=389
Good Luck
Feb 11, 2013 | Hoover UH30010COM Bagged Vacuum
Machine has no lights or power.
Our Whirlpool washer is GVW9959KQ0, bought in September 2001, in September 2010 it had the problem as follow. When the panel was lite up, it was always set at "44" minute, NORMAL wash, no touch area is responsive, not even STOP or START. I could turn off the panel completely by pressing STOP and "Whitest white" in sequence quickly. When the panel was shut off, I could turn on the panel again by just pressing "STOP"; But the panel was back to "44" minute, NORMAL wash. Unplugging the power did not help (see as follow). That was the washer life for a couple weeks. We left it w/o power for 24 hours, it worked again normally just for 1 wash, and it was back again to the zombie mode; left it again for 24 hours, no luck, left it again for 24 hours, worked again for just one wash. We managed to wash 3 loads during the 2-week period (just 1 wash per time). Since the washing functionality sounds and looks working well to me, I thought that the panel might be the culprit. Finally we ordered Control Panel Assembly (Parts AP3884746, it is just the panel part where we touch for washing selections w/o electronic boards behind it) at appliancepartspros.com (cost $178 regular S
Apr 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Wma44 hotpoint washer. Did a wash as normal and
Sometimes a weak or broken spring in the door handle can be the cause of the problem, but you would have to take the door apart to check this.
If you have already fitted a new door lock, then chances are it is the control board, but I would check the door handle first.
Jan 30, 2010 | Hotpoint WMA44 Front Load Washer
My Whirlpool Caylpso display is stuck and will not start
You can try unplugging it for at least two hours and then re-starting. Since I moved my washer starting acting up getting stuck at various points in a cycle--sometimes 19 minutes, or 12, or 33, or 3...no rhyme or reason, no specific point in the cycle. My mover is an appliance repair guy and told me to do the unplug thing and it has worked multiple times--not that I enjoy having this happen over and over, but he told me Sears would charge a minimum of 100 to show up at the door, and I don't have that right now. Anyhow, it has only worked if I left it alone at least 2 hours---my new strategy is going to be unplugging it daily...I love the washer but this is nutty.
Jun 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clean light flashes 7 times
try doing button setting change from "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine.
The process runs for about 19 min. and shuts off
During the process several LED's light up and several funtions start and stop.
If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. this is the method to reset the machine.
Most likely is that there were suds in the last cycle or the door doesn't close smoothly.
Jan 09, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Lights on Front Panel Flashing
Another posibility is the door lock switch is broken. When you open the door, on the middle right hand side there should be a small pin sticking out from the washer that the door pushes on.
Jun 13, 2008 | Kenmore Elite 45986 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Oct 15, 2006 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
96 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
