Hi, I'm looking for a user manual for the Casio College fx-100 calculator. Can you help?
Many thanks. Melanie
Here you are Melanie. There a few!
Casio Calculator Collector User Guides Manual
http://www.casio-calculator.com > Download > manual
... source of the manual. (It takes a lot of time to scan this). SL-800 (D) jpg file (1.5MB) FX-201P pdf file (5.6MB) FX-100 pdf file (0.9MB) FX-101 pdf file (0.2MB)
CASIO FX-100B MANUAL Pdf Download ' ManualsLib
https://www.manualslib.com > ... > Calculator > FX-100B
View and Download Casio FX-100B manual online. FX-100B calculator pdf manual download. ... Related Manuals for Casio FX-100B. Calculator Casio ...
fx-100AU User's Guide - AWS
https://s3-ap-southeast-2.amazonaws.com > wc-prod-pim
PDF
fx-100AU. User's Guide. E http://world.casio.com/edu_e/ ... After removing the battery from the calculator, put it in a safe place ... Moreover, CASIO Computer.
Casio fx-100 (College) - Calculator.org
https://www.calculator.org > calculators > Casio_fx-100
The Casio fx-100 is a scientific calculator with 10 digits precision and algebraic logic. ... You can download the Casio fx-100 manual from the manuals website.
SOURCE: Need user manual for Casio sl-200te
To change the tax rate, first press AC. Then press SET % for 2 seconds. Next, press TAX+, then enter the new or current tax rate. Enter the rate for a single digit tax rate such as 5% as 5, a single number; if you have a fractional percentage rate, such as 5.75%, enter it just that way: the 5, then a decimal and followed by 7& 5. Then press SET % again and you're done! I just did it on two of the calculators and it works. Hope this helps!
SOURCE: Casio fx-9860g ............ how to do percent operation
[OPTN][LIST] scroll right till you find %. Press the function first then the number. It gives you the percent.
Hope it helps.
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
SOURCE: i am a casio fx-82MS user. i would like to know
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
You can download Casio College fx-100 user manual from this link:https://drive.google.com/file/d/1iIBKjeD...
there is Casio College fx-100 emulator too.https://www.youtube.com/watch?v=bCB1tr5i...
?f you have real casio college fx-100 or wish you get emulator of College fx-100
