A few days ago I accidentally spilled a drink on my HTC. I quickly dried it off, and I was to believe that it was absolutely fine, with the slight worry some may have gotten in the speaker in the back. But since then it was working fine, until today. It died because it had no battery power so I put it on charge. When it was dead it showed the no battery power icon, and now it is charged it all locks and unlocks fine, and turns on and off fine. But when I unlock it, the screen is black. If I hold down the back button it will go blue until I click the home button then the black screen will come on again. The volume buttons and lock/power buttons work fine and the white icons at the top cam be clicked so they all come up too, but still black screen. Is this water damaged or another issue?
It is a water demage - with using to quickly you made it bad, I guess with pressing the screen you moved the water.
I would say ... give it another dry (smile)
Open the rear, take the batterie out ... mean let the mobile breath ... then leave it on a warm, but not hot place ... it has to stay on the side. We want that the water in the case vabours troughthrough the side buttos within the time.
SOURCE: HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
SOURCE: HTC Touch Screen malfunction
hi, i want to formate my htc touch phone.... i dnt want a number formate.... i want a clear full formate
SOURCE: htc locked touch screen mal functioning
Try mDesktop for remote control from your PC to unlock the phone.
SOURCE: My T-Mobile MDA won't turn on or take a charge, battery was low
I had the same problem, but got the idea to "jump start" the battery from Googling the problem. At night, I had turned off my MDA to charge the battery and then in the morning, couldn't revive it. I removed the battery from my MDA, and determined which battery terminal was positive (far end of one side) and negative (far end of the other side) by using a multi-meter. BTW: Battery was still @ 3.5V (okay…battery was still alive, if just barely). Then, I found a 5V DC charger (5W Max output = ~1A) from my bluetooth headset. I used one wire (CAT5E) and connected it to the negative side of the adapter (outer sleeve - again, verified by multi-meter) and another wire to connect to the positive tip of the adapter. I had to strip about 1/2-inch of the insulation off of the wire on the DC adapter side, and about 1/8-inch of the wire on the battery side. Plugged in the 5V DC charger and then I touched the negative wire to the negative battery terminal and held it there, while I touched the positive wire to the positive battery terminal for about 30-45 seconds. Put the battery back in the MDA, started it up, and now it's charging on the regular MDA AC Charger that came with the phone. Problem solved.
I’m happy to assist further over the phone at https://www.6ya.com/expert/daren_80e8def41854e57e
SOURCE: Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
