Question about Denon AVR-E400
Reciever shuts off
I have the avr-e400 just got it today my dad played it and it shuts off at a certain volume and why do I have to turn it up to like almost all the way before it even begins to have solid loudness it has 185 watts per channel what the use if I cant play it loud I used to have a Yamaha eciever that did the same thing took it to shop they said circuit in power supply board was bad can that cause this issue
Posted by Jason Kuziej on
  • Jason Kuziej Feb 04, 2014
    i have huge speaker they stand almost as tall as me they are definitve speakers this reciever dont like to be played loud people dont buy big reciever just to play stuff at a whisper level
    and the watts the speaker can stand the tall ones can go up to 600 watts surround speakers can go up to 250
Audio Service Clinic
  • Denon Master
  • 924 Answers
Hello. Please let me set the facts correctly. The specs on your receiver are 75 watts per channel into 8 ohms (20-20,000 Hz) at 0.08% THD, with 2 channels driven.
What this means is, you're pushing the receiver beyond it's limits. You will need a much larger, more powerful receiver to satisfy your need for power.
You can't compare your old receiver to this new product. Even the volume control indicator, actually works the opposite of what you may think. The control is actually acting as an attenuator(through a microprocessor(computer inside your receiver), so you will notice the numbers going down, as you're turning it up. When you turn it up in volume, the display shows you the lack of attenuation. It's just a different, more technical way of saying the same things.
Bottom line is, this receiver is not nearly as possible as you may have thought.
Posted on Dec 17, 2014
Steve K
    Genius:
  • Denon Master
  • 1,054 Answers
Most likely cause of a receiver shutting off when turned up is a bad speaker or speaker wire.
As far as having to turn it up almost all the way, that is the norm on most new receivers today. Most receivers no longer have a true preamp section, which means you have to run the main amp much harder in order to get a decent sound level.
Posted on Feb 04, 2014
5 Related Answers
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Posted on Jan 17, 2009
Anonymous
SOURCE: AVR 2807 shuts off at high volumes
I had the same problem. Rebooting did the trick. Reboot the unit per the instructions provided by another user on the main page. Here they are:
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory.
Anonymous
  • 36 Answers
SOURCE: avr 3806 power shuts off when volume turned up
Hello david 420
It looks like your receiver's high-speed protection circuit is being activated. It is definitively not a fuse. When a fuse pops, you have to physically replace it. When the protection circuit is activated, the speaker output is cut off and the power supply indicator flashes. There are a few reasons why this happens:
1.- Your speaker wire connections are loose. Whether they are banana plugs or bare wire ends, make sure the speaker terminals on the back of your receiver are tight using clockwise turning.
2.- Verify that your speakers have an impedance between 6 and 16 ohms. Your receiver was designed to work with that impedance range. Any impedance lower than 6 ohms will activate the protection circuitry.
3.- The receiver is used at high volume levels over a long period, which results in an
extreme temperature rise. Improving the ventilation conditions around the unit might help alleviate the problem.
If after complying with these suggestions, problem is still present, you might need to have the unit checked by a professional for possible circuit failure.
Hope this helps. Let me know.
cancerags
Posted on Dec 31, 2007
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Turning volume up on my Denon AVR-485 AMP causes it to turn off
Speaker Impedance:
When speaker systems A and B are used separately, speakers with an impedance of 6 to 16 ohms can be connected for use as front speakers
Be careful when using two pairs of front speakers (A + B) at the same time if their impedance is less than 12 ohms.
The protector circuit may be activated of the set is played for long periods of time at high volumes with an impedance lower than specified are connected.
Posted on May 04, 2009
Anonymous
  • 41 Answers
SOURCE: connected denon avr 1800 reciever to new hd tv. i
If you connect your tv's audio output to the reciever's audio input in the (TVor video section) using audio cables only---red & black or red & white) then select TV or Video on the front of the reciever depending on which connection on the back that you use it should work fine!!
Posted on Nov 06, 2009
How to connect a denon avr-e400 receiver to a televion
If the DENON has an HDMI output, and your TV has an HDMI input, then use a HDMI cable. Then, use the TV's remote-control to select "source" (or "input") as 'HDMI 2' or 'HDMI 3' (assuming that you have been using 'HDMI 1' to watch TV).
Feb 08, 2015 | Denon AVR-E400 7.1 Channel 4K and 3D Pass...
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
Denon avr-1708 receiver heats up and shuts off when volume turned up passed 0.0db or +0.5db. i am running 6-8" sonance 6oh speakers and have a fan blowing across the top of the receiver. it only...
Are you trying to kill it? A device has only so many emergency shut-offs it can withstand.
How are the spaces around the top, underside and back for ventilation?
0 dB isn't normally 'normal' volume.
I wonder if the fan is a self-defeating work-around because the noise might make you want to crank it up so higher so you can hear it.
Apple TV? Is it a dynamically-compressed audio signal? That would raise the average volume.
Feb 21, 2011 | Denon AVR-1708 Receiver
When reciever is turned on it shut's right back off. It will not stay on. Also it would loose volume. Why is this and can it be repaired?
this is a main power issue and the only way to fix it is to replace the main board which is the heart of the reciever . costly exercise . sorry to hear that
Sep 27, 2009 | Harman Kardon AVR 510 Receiver
My reciever is shutting down completley when i try to turn on the second zone. i tried rewiring it but it still does it could it be the reciever or do i just have the settings incorrect?
if the reciever shut down with zone 2 on, zone 2 volume at -3 and nothing connected to zone 2 it needs repair if not reconnect the speakers to zone 2 speaker connections and make sure you do not have more than 4 pair of speakers with impedence matching volume controls or a impedence matching speaker selector box
Jun 15, 2009 | Denon AVR-785 Receiver
Jan 17, 2009 | Denon AVR-3801 Receiver
Speaker Impedance:
Oct 16, 2007 | Denon AVR-485 Receiver
Denon AVR-E400 Logo
277 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
