Question about Wolf Range Ovens
Led panel light stopped working on my wolf electric oven
5 Related Answers
Anonymous
  • 254 Answers
SOURCE: Wolf oven stove top starting problem
This is caused by a bad flame sensor switch. It has a cap tube (copper line) coming from the pilot area to a switch with two wires on the backside.
Hope this helps You
please rate me
Posted on Jul 23, 2008
Anonymous
  • 3 Answers
SOURCE: Oven not working
In this case, I would check the following:
  1. Make sure the oven is receiving power. Turn the power off and on at the circuit breaker.
  2. Pull the oven out of the wall and inspect the control boards. Look for burned areas. The power area could have burned out or the control card probably burned out.
  3. Personally, I think that in this case, the are that the whole computer card will need to be replaced. It runs over 100$ in parts.I think this because it's happened twice to me -- once when we had a power surge in the house, another time when I simply replaced a light bulb in the oven.
I hope you will post back what the actual solution was.
Posted on Dec 28, 2008
johnrodgers1
John Rodgers
  • 80 Answers
SOURCE: How to light a Wolf Gas Oven, model PW362718,
you cant !!! need power to operate if it has a glow coil ignition
Posted on Feb 06, 2010
Anonymous
  • 351 Answers
SOURCE: oven has stopped working -there are no lights on
sounds like the control has gone bad
Posted on Oct 03, 2010
burkcs
burkcs
SOURCE: Whirlpool Double oven control panel
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
Posted on Dec 24, 2012
How do i find the fuse location for a Wolf double oven, Model D030F/S ?
Dear Friend,
Pull the oven towards you, disconnect any electrical cord from the wall. Normally the fuse is located right next where the electrical cord enter in the back of the stove. If there is any panel right on top of where the electrical cords connects to the oven, simple removed that cover and there should be a fuse. If not, removed the rear panel where the electronic control panel is. Hope you can find it!
Good Luck!
Sep 20, 2014 | Wolf Range Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
LED display stopped working
Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
Jan 04, 2009 | Belling XOU252 Electric Single Oven
Hope this helps You
please rate me
Jun 02, 2008 | Ovens
Ovens Logo
44 people viewed this question
Top Wolf Range Ovens Experts
Harjeet s. bola
Harjeet s. bola
ray gallant
jenifer ronan
jenifer ronan
Level 1 Expert
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
