Question about GE Cooktops
GE JP345 Cooktop
The largest eye is not cycling all the time and staying on when it is turned down and remains heating. Does not do it all the time.
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Posted on Dec 30, 2007
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Posted on Mar 02, 2009
Anonymous
SOURCE: Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
Posted on May 29, 2009
Anonymous
  • 116 Answers
SOURCE: I have a GE 30
Hi sounds like you have a busted switch assembly, this is very much fixable the part is around $50, but you would need to remove the top of the stove which requires pulling the unit from the counter, this is slightly more involved, but definitely doable i would also change the knob. A more accurate name would be infinite switch.
Sean
Posted on Mar 28, 2011
Gere knutson
  • 842 Answers
SOURCE: GE gas cooktop modelJGP970BEK2BB. The
The lock switch will need to be replaced. Lock switch, the switch has failed and causes the buzzer to run. Not a difficult repair but the top will need to be remover to fix this. This is not advisable to repair if your not knowledgeable with the installation part of this unit.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Oct 10, 2011
Cook top indicator lights stay on long after it has cooled off. The largest cook circle sometimes doesn't reduce heat when the dial is changed
Cook top indicator light will stay on as long as the stove is hot I think. Also, the burners don't heat real steady? or evenly or true to their settings even, quite often. they also take a really long time to cool down as well as to adjust temperatures, so it may just be that it is taking an awfully long time for it to cool down in order to adjust.
Apr 04, 2015 | Cooktops
Large eye thermostat is not working. Heat stays
Hello JBlum, Yes, most stove top elements, including those with the thermo sensors, are replaceable. Without the model number, I can't steer you towards the exact part number, but you can look it up yourself at www.searspartsdirect.com
Just enter in the full model number of your GE range and it will bring up all the line drawings and parts lists for it. You can either order the parts from Sears, or use any other supplier you wish.
Just remember to disconnect the range from the wall outlet before you undertake any repairs or attempt to replace any parts, so you'll be safe.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | GE Cooktops
Hot Surface Indicator Light has not turned off since last night.
if the hs ind light does not turn off then that particular heating elemnt needs to be replaced.heat sensor is built in the elemnt.when elemnt is turned off and it cools down it makes a switch to open and inturn ind light turns off.but sometimes thst gets stuck and light remains on.but do not worry abt element,it remains off,its just that indicator light that remains on.
Jul 30, 2009 | Jenn-Air JED8430 Electric Cooktop
May 21, 2009 | GE Cooktops
Light sill not go off, and eye stays very hot. Must cut off at breaker
Hi, You will need to change the switch for that eye. If you give me the model#, I can help you with part#.
THanks
Vic
May 15, 2009 | Cooktops
Stove top will not heat oil hot enough to fry foods. Burner continues to re-cycle on and off while switch is on high. Burner gets red hot for a few seconds then turns off for a few seconds, then back on.
You may have a cracked element, they expand when heated and cause a separation in the element. You really have to put a voltmeter on it to test it under load. If the voltage remains constant while the element is heating and cooling, then indeed you have a bad element.
If you don't have a voltmeter, or don't want to perform this test, buy a heating element and replace it, if you have the same problem, you'll have a spare element
May 14, 2009 | Jenn-Air JED8430 Electric Cooktop
Frigidaire glass cooktop
first try putting pans on top and see what they do you should not operate these type of eyes with nothing on them as you will burn out the sensors in the eyes if nothing is there to reflect the heat back to them if it does the same thing with pans on them then you will have to replace the elements
Feb 11, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Dec 29, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Cooktops Logo
119 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
