Question about Sunbeam Heating & Cooling
No power is there a fuse or cut off switch on a Vulcan Quasar Elite G Series HEATER
Posted by bromsplace on
Anonymous
Not sure wot series mine is, but has 2 thermal, non resetable fuses in it. They are plastic cased (brown) with 2 spade type terminals. You can check them with the power off if you are not confident with the mains.
Make sure it is unplugged. Pull one of the spade clips off the terminal and then check it for continuity.
Posted on Aug 12, 2009
Complete cover or fascia for vulcan quasar wall Heater console model
Contact Authorized Service Center or Authorized Dealer.
Mar 29, 2014 | Heating & Cooling
Vulcan quasar elite heater 2400w, trying to find operating instructions
May I get the model # so I can get you the right manual
Jun 20, 2010 | Heating & Cooling
Is vulcan duct heater still in existence? My problem is the thermostat control for the room temp has gone out of control - from 22 -35 0C. This has affected the heater cut off efficiency.
Yes. Vulcan heater company is still making heaters. Here is the link. http://www.vulcanelectric.com/
Grainger is a direct seller of Vulcan heaters, so you chould be able to give them a call, explain what you need or giver them a part number and they will be able to get what you need.
May 12, 2010 | Vulcan AUW230A Heater
My dryer model kenmore 110.85862400 has power but does not turn on...is it possible that I locked it somehow? Do you know how I can unlock if thats the case. Someone told me to check fuses or breaker as...
Faulty door button or faulty thermo cut out located on the heater housing Check for oms Door switch when pushed in and thermal switch when power is applied
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Vulcan Quasar 40 air issue
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Jul 27, 2009 | Heating & Cooling
Vulcan quasar 40 shut down when fan starts up
Replace the fan thermal switch located at the top of the heat exchanger. Unplug the power first as the switch is 240V.
Available from any plumbing trade shops e.g. Reece & Tradelink
Jun 03, 2009 | Heating & Cooling
Vulcan quasar elite heater does not display led readout or any lights when plugged into power point the point and switched on.
this is not an air conditioner but a fan forced heater. The control unit has died and a replacement is over $170.00 !! It's going to be recycled.
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
248 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
