open the back of your amp and see if the leads from the fan are burnt anywhere. trace them from the fan to where they are soldered into the board. if the wires appear to be fine, then test them using a volt meter. if the positive is not recieveing power you may want to solder the lead to your remote turn on.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
