SOURCE: problem with startup
Now something that will actually help you.
1) the reason this is most likely happening is that the lens is blocked.
how i fixed this was (I'm not kidding) I hit mine against a card board box. and that dislodged the lens, now it works. you can also just try taking it apart and cleaning it. that gave me an electric shock so be careful.
hope I helped you.
PS "you might need an idiot to do this for you. no kidding."
SOURCE: low battery
Your cam has a not so rare battery drain defect, mine had the same problem.
call Samsung and send yours in, they will either fix it or give you a new one.
SOURCE: displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
SOURCE: L 100 digital camera is not switching on though the battery is fully charged.
Try removing the battery for a couple of seconds then insert it again. Click on the power button, it should turn on and turn it off again to close the lens.
