Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier Logo
Question about Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier
My car stereo has a hum . midrange amp signal hums and bass amp signal is fine.
Posted by jeronedunbar on
Anonymous
  • 655 Answers
Hello jerondunbar,
Most often a hum is caused by a "ground loop" problem. The hum is produced when there are slight differencies in the ground potential of one or more of the components. Ideally, all of the grounds should be at exactly "0" potential and this would be the case if we did not have to contend with rust and corrosion and other nasty things like loose connections and frayed insulation.
First, check all of the ground connections and make sure they are good and tight. Then, isolate what component is actually causing the hum. Disconnect the amp inputs and see if the hum is still there. If it is, it's most likely the amp. If not, the head unit. Reground whichever unit is causing it and you should be OK. If not, you may have to resort to installing an inexpensive in-line ground isolator available from www.crutchfield.com, www.partsexpress.com and other online stores. They may also be available at your local audio store or Best Buy.
It's also possible for hum to be introduced into the system if the input wiring is routed too close to a power wire. In this case, it's best to reroute one or the other. In persistent cases, it may be necessary to replace the cables with a shielded type.
Hope this helps.
Posted on Jun 06, 2009
Ok problem with monitoring
If you are experiencing a mid-range humming from your monitors when using your Allen & Heath PA12-CP mixer, there may be a problem with the signal level or the cables.
Here are a few steps you can try to troubleshoot and resolve this issue:
  1. Check the signal level of the sources that are being sent to the monitors (e.g. kick drum, snare, etc.). Make sure they are not too loud or too quiet, as this can cause the limiter to engage and create a humming sound.
  2. Check the cables that are connected to the monitors. Make sure they are not damaged or loose, and that they are properly connected to the mixer and the monitors.
  3. Try using a different set of monitors to see if the problem persists. If the humming is still present, the problem may be with the mixer itself.
  4. If you are still experiencing a humming sound, you may need to contact Allen & Heath customer support for assistance. They will be able to provide you with more detailed troubleshooting steps and help you resolve the issue.
Overall, if you are experiencing a humming sound from your monitors when using your Allen & Heath PA12-CP mixer, the problem may be with the signal level, the cables, or the mixer itself. Follow the steps above to troubleshoot and resolve the issue.
My phd2 amp is hooked up but it making my subs hum for some reason no bass just a loud hum y is this
bad amp its getting a bypass voltage to the amp when powered down sell the amp, if it is the grey model email me [email protected] i might buy it
Wiring power house phd2 mono amp to the earthquake 4 ohm speakers.
When i hooked up my bass knob the amp made my subs hum i unhook the rca but still humming unhook bass knob still hummin
Sony TC-530 hum in internal amplifier left channel.
Electrolytic capacitors are good at causing hum. You could try replacing some of them, they are not expensive. Otherwise you might have damaged the left channel amp semiconducter, whatever that might be.
1helpful
2answers
Car stereo pre-out signal noise
Two things, a ground loop isolator in-line with the RCA's between the head unit and the first amp.....also a noise reducing capacitor ( $5 or$6 at an auto parts store) on the alternator 12v post will reduce or remove the hum.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
1helpful
Humming sound to speakers from amplifier
It sounds like you may have a ground loop issue. I'd start by checking all the power and ground connections. Then disconnect the RCA wires from the amplifier. If the hum goes away then you should try grounding the stereo to a better grounding point, the factory grounds are usually not very good at all. Then try it again, if it is still there try replacing the RCA"s.
If the hum is still there after you've redone the connections and replaced the RCA's, you may need to install a ground loop isolator.
Both www.crutchfield.com and www.sonicelectronix.com sell good ones.
Hope this helps
Fender Rumble 100 210 pop noise then hum after strong low e note
I just fixed my bass amp with a similar problem last week: the problem is related to a loose connection on the PCB board (likely).
A bass amp is a rough place for circuitry: the low rumble and power shake a bass amp more than a guitar amp.
In my case, the power transistors needed to be re-soldered and then the grounding bolts and screws needed to be removed and cleaned because the connection was bad. Remember that when two different metals needed for an electric connection are toughing, there is the likelyhood that corrosion WILL happen.
My bass amp did basically the same thing yours did: sounded good at low volumes, but at higher volumes it would act up.
In short, there is nothing you can do (unless you are a repair person): you need to take it to a local music shop and have a tech fix the intermittant contact problem: someone who knows what they are doing should only take an hour at most.
Hope that helps!
-mike
5helpful
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
2answers
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
1helpful
2answers
Subwoofer probelm
I suspect you have a bad cable, a poor ground or a bad
power supply inside the speaker amplifier. The amplifier
(inside the sub-woofer) could also be defective.
1) Bad cable or connector:
If the (braided shield/outer tube) of the coaxial input cable is
not grounded, the cable will pickup line frequency "hum"
from surrounding power lines, house wires, lights and
appliances.
This hum is then amplified by the speaker's amplifier
causing the constant bass sound you speak of.
Because the hum frequency fundamental is 60 Hertz in
North America, 50 Hertz in Europe, you hear it coming
mostly out of the sub-woofer, because the midrange and
high speaker circuits filter it out.
Check the input connectors, cable at both ends, wiggle
the jacks at a low volume setting to see if it changes.
Make sure that you are indeed using a properly shielded
coaxial cable.
A coaxial cable consists of a thin inner conductor, surrounded
by a flexible tube made up of a braided metal shield, which
must be grounded. This prevents hum from being picked up
by the sensitive amplifier inputs.
2) If the power supply within the sub-woofer's internal amplifier
is defective, the the power supply hum will also get coupled
into the amplifier and speaker with same results as above.
Power supply hum is typically twice the line frequency,
i.e. 120 Hertz, but not always, depending on what
component failed: Rectifier diode, filter capacitor, or
the voltage regulator.
3) Ground loops:
When you run very long cables between the source and
destination of an audio signal, multiple ground paths (must)
exist between the two points in space, creating complete
loop circuits.
Power line hum from the environment can (will) induce
heavy AC currents around these loops, creating a voltage
gradient across these cables, and in-between the end
devices.
Once again, this AC hum is coupled into the amplifier inputs.
Ground loops become a problem with cables over 10
feet long, and an astronomical problem for stage audio
engineers. To avoid ground loops, they must break
the circuit's continuity by using isolation transformers,
optical isolators, and/or differential input amplifiers.
So how long are your cables?
Most house stereo components are only designed to
handle 6 to 10 feet of cabling max.
30 feet is already asking for major trouble.
4) Feed back oscillation: This occurs when the output of
an amplifier is fed back to the inputs with a round trip
gain greater or equal to unity. The tiniest little electrical
disturbance is then amplified and re-amplified, over and
over again, usually at one preferred frequency, causing
the typical (ear-splitting) microphone squeal or howl.
In your situation feedback and/ loss of original signal
could be the result of mis-wiring the input cables.
Note that this is NOT as silly nor as unlikely as it sounds,
because many computer audio cards and even some
home stereo systems have re-configurable inputs and
outputs.
SOFTWARE configuration decides which jack at the
back does what !!!!
On my computer, for example, the Realtek audio driver
tries to automatically figure out what cable is connected
to each jack (usually it gets it wrong)
Using the Realtek control panel applet, I can then
manually re-configure the gray jack as input,
the green jack as bass, pink jack as center.... etc.
If this situation also applies to your system, please check
the software configuration. Connecting an output cable to
an input jack will certainly cause a lot of HUM and not
much music.
5) Finally, don't rule out internal sub-woofer failure. Unlike
the passive stereo/hi-fi speakers of days gone by, modern
multi-channel theater systems with front, center, rear and
sub-woofer speakers are internally amplified, with active
frequency cross-over filters and special effect/ surround
sound capabilities.
Usually, the large sub-woofer contains most of the
electronics, amplifiers and filters.
It feeds the other speakers, and it is controlled by
an external volume control module which can be separate
or built into one of the tweeters.
These sub-woofer electronics are prone to poor design,
overheating and early failure. (Even fresh out of the box
like yours)
If you cannot get it working, take it back to the store,
and make the NICE salesmen **** with it.
Good luck
Please rate my answers
Martin.
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
