2006 GMC Yukon Logo
Posted on Jun 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
04 GMC Yukon won't start on less than 1/4 tank of gas
I have a 04 Yukon that does not want to start on less than 1/4 tank of gas and it has sat over night. You can run it until its bone dry and it will run fine. You can also have low levels of gas and go out and start it after an hour or two or three and it will start fine. It's just that eight hour period that seems to effect it. Also I can hear the gas tank expand and contract (pop) after starting and shutting off. I don't believe it's the fuel pump because it does not run rough when fuel is low, and I do not make a normal practice of running on low levels of fuel. Any ideas
Jonah Oneal
Level 3:
  • GMC Master 14,092 Answers
  • Posted on Jun 06, 2009
Jonah Oneal
GMC Master
Level 3:
Answers
14092
Questions
0
Helped
7239915
Points
44533
Have your evaporative emission control system check.sound like you have purge valve solenoid not working or vent valve control solenoid.have it scan.to see which component not working..reason your gas tank expanding. your fuel vapor building up pressure.your purge valve and vent valve open allowing gas vapor from charcoil canister. to be burn in the intake manifold to be burn in combustion chamber.
2004 gm yukon wont crank.
It is not necessarily the flow of gas that is important. You need at least 40 pounds of pressure for the injectors to operate correctly.
Car wont start when parked on hill
I HAVE THIS EXACT PROBLEM. If you got this repaired, what was the fix??
2helpful
Ran out of gas and now it won't start after adding 5 gallons
the fuel pump is cooled by gas so if u run it low alot or {OUT} it can burn it up
keep that tank at 1/4 or u will pay!!!
1helpful
2001 gmc yukon xl was jerking, cut off. will not start.
it sounds like the fuel pump might have died, or blew fuse or relay see if it gets fuel at the motor
Have 2002 Yukon that won't start if under 3/8 or 1\4 of gas
hi, the banging on the tank is a typical fuel pump scenario , but to last for years is not very likely , i think it needs to be diagnosed to see what's missing when it wont start .
1helpful
2004 GMC Yukon won't start if less than 1/4 tank of gas
sending unit for gas gauge is not correct
2helpful
2answers
If I have less than 1/4 tank of gas my yukon won't start.
I had the same problem. I had a few different mechanics tell me that the fuel pump is starting to go out when it does that. The fuel pump is located in the fuel tank, and the gasoline keeps the pump cool and lubricated. When the fuel tank is less than a 1/4 full, the pump is not submerged anymore, and can have trouble sending gas to the engine. My emergency fix was to get underneath the car on the driver's side and bang on the gas tank about three times. It will start up, and will run great unless you turn your engine off. But eventually you're going to need a new fuel pump. Once I replaced it, the problem went away.
2answers
GMC YUKON will not start with less than a 1/4 tank of Gas
check fuel filter could be blocked,if it s ok check fuel pressure if its low ,fuel pump
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
