Question about Science & Laboratory
How do you escape level 38 on 40x escape - Science & Laboratory
Location oil pressure sender unit 2002 ford escape xlt v6 3.0
check for correct oil level in the sump first
this indicates insufficient oil level and the surge of the oil when stopping is allowing air into the pump and putting the light on
Sep 17, 2016 | 2002 Ford Escape
How do i check trans fluid level on my 2005 ford escape limited 4wd.
should be a dipstick near the battery,if not theres a plug you take out and check the level in drive engine running
Jul 07, 2015 | 2005 Ford Escape Limited
How to check the transaxle fluid level on a 2002 ford escape xls v6
Locate and remove speed sensor. level and fill piont
Nov 17, 2012 | 2002 Ford Escape
2001 ford escape has no heat and my collant maybe leaking
well no heat and could be leaking could be a bad heater core stuck open thermostat and just low coolant level..
you say it could possibly be leaking from were
May 09, 2011 | Ford Escape Cars & Trucks
I have a 2001 Ford Escape. The warning light for the rad comes on after the truck has run for 10 or 15 minutes - have checked all the levels and everything is good. Any ideas?
You may have a bad sensor in the resevior. You can try tapping on the resevior and see if sensor comes free and light stays off. The coolant level sensor or collant temp sensor could be bad.
Oct 28, 2010 | 2001 Ford Escape
Ford escape 2001
Check coolant level in the recovery tank, if full probably a bad level sensor. Part of the tank.
Dec 18, 2008 | 2001 Ford Escape
Science & Laboratory Logo
144 people viewed this question
Top Science & Laboratory Experts
Tom Chichester
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
