SOURCE: sound drivers
u can try this if u understand
http://support.fujitsu-siemens.com/Download/ShowDescription.asp?SoftwareGUID=CB518FBD-386C-4266-8730-432160E331E7
or if u have the drivers and utilities cd with u,u can install the drivers from that disk also,or check this out
http://www.helpdrivers.com/ingles/doc/instal.htm
try this out
Go here and enter your details...
http://www.fujitsu-siemens.com/support/linkapplication.html?LNG=EN&ID=263
Try Everest Home Edition (for free but you've got to Google for it))
and then to driverguide.com to pick it up, if the Fujitsu site doesn't
help with it.
u need to install this driver for ur audio for the laptop
AC97 Compliant CODEC: Conexant Cx20468 driver:-)
Now try again here and click on c1020...
http://www.fujitsu-siemens.com/support/linkapplication.html?lng=en&id=263
and when u install the driver from griverguide.com follow this
After you installed the latest VIA AC'97 Enhanced Audio Controller driver from Driverguide.com , did you check the Device Manager?
What is seen in + Audio video and games Controllers?
Since you have tried to install other drivers, I am wondering if you could have corrupted the drivers.
If you have got the Right Drivers saved , I would suggest the following:
1. Start the Computer in Safe Mode
2. Open Device Manager> + Sound, video, and game controllers
3.Uninstall everything EXCEPT audio codecs, Legacy Audio Drivers and Video Codecs
4. Close Device Manager
5. Restart the Computer.
6. When the new hardware found message comes direct the wizard to the downloaded driver for installation
the audio controller is audio controller is a VIA VT8233 AC97 Audio Controller. VIA Technology website and download the VT8233 drive and it will definately work...good luck
SOURCE: disassemble fujitsu siemens lifebook c1020 to replace motherboard
try downloading a maintenance manual.
they are quite helpful.
SOURCE: Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
SOURCE: how can i start reformatting
How to Format a Hard Drive in Windows XP
