SOURCE: Sound ASUS P5S800-VM Motherboard
Pls go to
http://support.asus.com/download/download.aspx?SLanguage=en-us
This is the Asus download site...
SOURCE: ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
SOURCE: ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
SOURCE: MOTHERBOARD DRIVER P5S800 VM
DEAR ERD KANT
PLEASE GO THROUGH THE GIVEN LINK ,HERE YOU CAN DOWNLOAD THE DRIVER OF P5S800 VM.
LINK:-
http://nodevice.in/driver/P5S800-VM/get34065.html
GOODLUCK
