Question about Hitachi 53SBX59B 53" Rear Projection Television
Can't adjust color green on 53" hitachi magic focus tv
All colors look good and clear, but when watching football or golf, grass is gray to black
5 Suggested Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Hitachi Mode; 53UDX10B
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
Ecollier2012
Edward
  • 3459 Answers
SOURCE: Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
techman007
Lavell Turner
  • 1112 Answers
SOURCE: Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Posted on Oct 24, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Posted on Dec 12, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: magic focus error Hitachi 51F500A
ok, you have more than 1 post for this set--this model uses two of the STK-392-110 OR 392-150 Convergence chips.
If magic focus will not adjust the picture both chips need to be replaced--about 13 dollars in parts if purchased on Ebay.
Green is not offered to be adjusted since it determines the geometry of the picture--red and blue are adjusted to it.
Let me know how much skill you have and I can tell you how to fix the set--it requires two things--getting at the chips and being able to unsolder and replace them--there may or may not also be some resistors around them that are now bad and need to be replaced.
most shops get 300 or more for this repair--total parts cost if you are able to do it yourself is under 30 dollars.
If this helped you rate this solution as I do this here for free.
SD TECH
Green tint
Go to a channel that is in black and white and turn color all the way off.
Screen should be a black and white or gray color.
If green there is a fairly easy way to adjust--let me know what you find and I will tell you how to attempt the adjustments.
Feb 18, 2012 | Hitachi 57S700 57" Rear Projection HDTV
How do i adjust the magic focus?
  • Press "Menu" on the remote select the "Magic Focus" option in the Video menu or press the "Magic Focus" button on the front panel to adjust the convergence of the three picture tubes that create the proper color for the picture. Pressing the button on the TV initiates the automatic adjustment, and accessing the feature through the Video menu allows you to choose automatic or manual adjustment, though the "Automatic" setting must be selected for the button on the front of the TV to begin the process.
  • Aug 04, 2011 | Hitachi 53UWX10B 53" Rear Projection...
    My hitachi 53udx10b was supposedly just serviced but the picture is extremely blue. Have tried adjusting picture to no avail. Help.
    I am going to tell you a simple thing to do to know what your problem may be.
    With the set on turn the color all the way to zero. Go to a channel if you can that is in black and white. What color is the screen?
    If the answer is that it is blue in the background whoever serviced the set did not and could have removed front speaker grill and inspection plate behind it; there is a black plastic block with three screen controls (red,green,blue) and 3 focus controls (do not touch the focus ones.)
    I suspect if the blue screen is there a slight adjustment of the blue screen down will correct this.
    The picture with the color at zero should be black and white or gray. If blue is background color it will also be with color.
    This is called gray scale; picture with color off has to be gray or black and white.
    Before you rate this solution if you have questions make a comment right here and I will advise you.
    SD TECH
    Jun 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
    I have a Hitachi 53FDX20B projection TV. The Red color seems to bow. I have tried to perform MAGIC FOCUS to no avail. Additionally, I took the front panel off to manipulate the adjustable knobs. What I...
    problem will be either Bad resistors ,in front of the Convergence ICs or ICs and resistors need to be replaced. ICs are big black ICs and will have part number on them STK392-110 use 120s or 150s
    Mats Electronics has Parts ask for Convergence repair Kit. 1-800-628-1118
    Mar 01, 2011 | Hitachi 53FDX20B 53" Rear Projection...
    Magic focus error Hitachi 52
    SD TECH
    Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
    Oct 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
    Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
    Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
    Common Symptoms include....
    • Screen looks 3D
    • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
    Here are some photos of convergence problems.
    Using your original remote go-to the settings menu then goto the convergence section.
    You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
    If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
    Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
    69189a5.pngCONVERGENCE SOLUTION
    You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
    This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
    May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
    I HAVE A HITACHI PROJECTION COLOR TV. MODEL 53UWX10BA 52". I JUST MOVED THE TV BY TRAILER FROM ONE TOWN TO ANOTHER, ABOUT 25 MILES, WHEN I PLUGGED THE TV BACK IN AND HOOKED UP THE CABLES, THE PICTURE WAS...
    Replace the convergence Ic's with a kit that is available through your local parts distributor
    You must replace all resistors in the kit
    If you are not good at soldering and de- soldering have a local tv shop do it for you
    Good luck
    Jan 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
    My convergence adjustment is not aligned
    The fact that the magic focus doesn't work means your convergence ic's are shorted or bad
    They have a kit for this tv it is available through local parts distributors
    If you can't find it locally just Google HITACHI CONVERGENCE KIT
    If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
    If you are not sure about doing this repair you should have your local tv guy do it for you
    Jan 21, 2009 | Hitachi 53UDX10B 53" Rear Projection...
    Hitachi 53SBX59B 53" Rear Projection Television Logo
    32 people viewed this question
    Top Hitachi Televison & Video Experts
    matt martin
    matt martin
    Todd Hill
    Todd Hill
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
