Well (other shoe drops) why not unplug the TV first
NO PC told
no windows version told
did you blow out the optical port first of line on mouse bottom
did loose the mouse pad (or soaked on coffee)
are the mouse batteries first, ong simple
does wired mouse USB work, hummmmmmmmmmm??
Made an account to say, for anyone else having a similar problem, what fixed it for me was blowing into the sensor hole on the bottom to get dust out.
The mouse is not something that is repaired and yours is defective.
SOURCE: Mouse does connect but keyboard does not, vice versa
reinstall the logitech cd which came with keyboard and mouse, with the mouse pluged in. once reinstalled restart and while restart plug the keyboard in..... this should resolve the issue.
SOURCE: Logitech Mouse
Where do you have the transmitter sitting? If it is below a desk (i.e., sitting on top of the computer tower, etc.) it may not be emitting a strong or consistent signal. Try moving it within a clear line of sight to the mouse. If that doesn't work, it could be a problem with the mouse itself and need to be replaced.
Hope this helps, let me know
~ Genie-Us IT
SOURCE: Optical Wireless mouse does not connect
uninstall blue tooth software and start over from scratch.
SOURCE: My mouse will suddenly stop moving new battery doesnt help
Is there a resync button on the bottom and on the base station (that is on the end of the usb plug that you plug into your computer)? Press the one on the base station first, then the one on the mouse within a few seconds.
You could also:
Try another set of batteries.
Try another USB port.
SOURCE: Mouse stopped working, but appears ok, batteries ok, can't determine problem
Hope this helps others. My mouse stopped controlling cursor but buttons worked. Problem was it would not work on a black table. Slip a piece of white paper under it and waaala! It works. I'm thinking optical mouse and dark surface might be an issue.
