Question about Dictaphone 2740 Desktop Cassette Transcriber / Recorder
Play wont work
Won't advance tapes
HP SureStor DAT24 won't exit clean mode, won't accept tapes
give it cleaning tape >>> once it finishs cleaning it will eject cleaning tape then you will be able to put any other taps
Apr 08, 2013 | HP Surestore DAT24 DAT Tape Drive
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Yoshi Island screen freeze GBA
the problem is in the tape. try to clean the tape by blowing
Feb 27, 2009 | Nintendo Super Mario Advance 3: Yoshi's...
Correction tape not advancing
watch to see if the tape lifts up and down. this motion actually makes the tape advance. if it doesn't go up and down something is prabably broken. (motor, motor wire, etc.) if it does go up and down and it still does't advance, check to see if the spool is snapped into place on the right side and there is tension on the tape. if it still doesn't work you will need to take it to a repairman.
Oct 31, 2008 | Brother ML-100 Typewriter
Dictaphone 2740 Desktop Cassette Transcriber / Recorder Logo
41 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
