Question about Altec Lansing VS2121 Computer Speakers
Acs295 diagram Computer Speakers - Altec Lansing VS2121 Computer Speakers
2 Suggested Answers
Anonymous
  • 141 Answers
SOURCE: i had a dell 2700 computer working with altec
First the easy things. Are you sure you plugged the speakers in the correct socket.
Are you sure the speakers are plugged in and the power switch on.
Is the volume turned up on the speakers.
Is the volume turned up on the computer, Not just the program you're running but also from the tiny speaker icon at the bottom right of your screen.
Have you checked the sound card (if it's not a built in system) is correctly inserted.
It sometimes helps, if it's a plug in card to remove the card, clean the card's contacts with clean white paper and then plug the card back in.
Check the card is actually working by plugging in another set of borrowed speakers.
Ensure you have drivers loaded for the sound card.
Check the system manager in your control panel and make sure there's no conflicts.
BE CAREFUL WITH THIS ONE......
Grab an almost flat AA or AAA battery and connect intemittedly one lead of the speaker to one end and the other wire to the opposite end of the battery. If you hear a clear crackle in time with the touching of the wires then the speaker should be OK. If you have a multimeter, switch it to OHMS and check the speakers on it's low setting. It should register around 4 Ohms. Even on high settings the meter will show a bunch of zeros or if it's a meter the needle will swing right across the dial.
If all these pass then I would be checking with a substitute sound card. But this would involve loading the appropriate drivers too.
Good luck.
Posted on Apr 06, 2010
johannluus
  • 4 Answers
SOURCE: need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Posted on Nov 11, 2010
HOW DO I GET THE ALTEC LANSING SUBWOOFER MOD. NO.ACS295 TO WORK WITHOUT THE SATELLITE SPEAKERS?
You would have to design and build a box that contains the controls normally housed in one of the satellite speaker enclosures.
Nov 19, 2017 | Altec Lansing Audio Players & Recorders
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Can I hook up acs295 speakers to my laptop
I would say yes. Plug into headphone jack. Hree's the user manual: http://img.4pk.ru/26663.pdf
Nov 30, 2012 | Dell Latitude D610 Laptop Computer -...
I need drivers for altec lansing acs295 speakers...I bought the speakers years ago and don't have any proof of purchase. When we updated to windows 7, they stopped working. I checked and replaced the...
Speakers don't need drivers, audio chips do. Go to the the site of the manufacturer of the pc, Support and Downloads section, locate, download and install the audio driver from Win 7 section for your pc .
Apr 21, 2010 | Dual Audio Players & Recorders
I had a dell 2700 computer working with altec asc295 speakers and the dell crashed. i connected the acs295 speakers to my other dell 4700 and they don't operate.
Good luck.
Apr 06, 2010 | Altec Lansing ACS 295 Computer Speakers
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Jan 30, 2010 | Altec Lansing ACS 295 Computer Speakers
Need wire diagram 4 altec lansing acs295 4 red connctor
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
Altec Lancing Multimedia Computer Speaker System ACS295
yeah. dude go to radio shack or a similar equivelent and they'll have all the parts as well as the instructions or even the abilities to fix it right there. Try it!
Nov 13, 2007 | Audio Players & Recorders
Altec Lansing VS2121 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
