Question about Nuova Simonelli Coffee Makers & Espresso Machines
Water level in site glass - Nuova Simonelli Coffee Makers & Espresso Machines
  • iyad tokath Apr 19, 2015
    What's wrong on it ??
Eric Ramos
    Habit-Forming:
    New Friend:
  • 103 Answers
What do you see? normally should be half level only.
Posted on Jun 11, 2019
1 Related Answer
vance jones
  • 120 Answers
SOURCE: I can not get water level to show nin the site
are you sure your not waterlogged?if you keep adding water and its not showing that is the first thing i would wonder
Posted on Feb 05, 2011
Do that wash should be able to see the water lever throught front glass door ? i don't see no water lever byt the clothes is wet is that normany ?
NO! If the water gets to that level then it is too full. The seal on the door is not made to hold back that much water.
Hi have a commercial expobar two group head, the site glass was leaking so sent it in to be replaced. Have installed new one in machine but no water to group heads? Should the relief valve on the water...
First, I'm not a Expobar technician. But I've worked on similar Professional espresso machines. Since this is a Professional unit I assume you have a close relationship with the service tech. So the following is for the tech:
* Yes it is possible to install the site level glass upside down. It will still work but the fittings to the tank also has to be switched. (Hey, I did that too!) But usually the tech will realize the mistake and re-do it as it will take longer the switch out all the fittings. Easier to flip it back.
* In most cases the indicator is usually mounted on a back plate that is fixed to the front panel or the site fittings themselves. It's a lot of trouble to put it back right, so if you did your own work (the owner) then suggest getting a black marker and remark the correct levels. (correct it later when you have time)
* Water in the site glass should come up at least half way in the glass tube. But not completely to the top and out of site! (filled) then the water level probe or float is not working and you will have water leaking from anti-vacuum valve and/or safety valve. Check float/probe system.
* No water to groups are another problem. The only common connection to tank and groups are at the water inlet fitting. it splits into several directions from that point. Tank fill, Hot water, Temperate steam port, and each individual group (I.E. 4 groups splits 4 ways)
* Many units have additional water treatment options that may be clogged or restricted (or turned off) check your "Manual fill leaver" if the lever works or has been cut off. Some have manual valve shut off for testing etc. It's usually under the drain tray or somewhere accessible.
* Changing the site glass requires work on the fittings that connect directly to the tank. I usually drain and clean out the tank at this point as the machine is completely disassemble to get at these parts. Good idea to check inside the tank for crud build up. Removing fittings will break off calcium deposits which will clog up other parts and valves up the line.
* Identify and locate the clog in each system. You will find that once a machine starts to calcify then it will spread all throughout the unit. Complete disassembly and cleaning will be required (lots of work and time) strongly suggest looking for a new replacement machine.
*** Do Not use ACID to clear clogs. This includes Vinegar as it's and acid! ***
Aloha, ukeboy57 (youtube)
1helpful
Where to see oil level 1100 honda shadow aero?
The oil level is observed through a site glass on the side of the transmission case, the site glass is about the size of an American Quarter.
I can not get water level to show nin the site glass. I keep adding water and nothing shows up in the site glass. It has no auto feed everything is manual,
Need to no why my bike dosnt have an oil site glass
not sure bout the 4 strokes but my 250sx has got a level plug around the water pump. have a look there
2answers
13helpful
2answers
Kawasaki 2006 KX450F Oil capacity I'm doing my first oil change on this machine after picking it up secondhand. Engine says .98litre with filter out, Manual says the same, however manual also says set oil...
Fill to the site glass. Anywhere from middle of the glass to just below the top of the glass. The engineers put the glass there for a reason. Typographic errors do come to light at times.
Top rating on the answer! Thanks. :)
5helpful
Whirlpool Duet GHW9400 Water Level Seems Too Low
Scott,
Believe me, if the water level were ever several inches above the glass, you'd know about it 'cause it would flood your laundry room. Seriously. See? That rubber door boot/seal is not water tight (like a submarine) when the door is closed and locked, it's water "resistant".
Front loaders often appear as though the level is low, but they are designed this way. The clothing actually tumbles through the water as opposed to soaking in water like a top loader.
All of that to say that you have nothing to be concerned about. Your water level is fine.
SG
p.s. If your water level switch had failed, as you suspected, the water level would be too high and leak out the door.
Washer makes loud rattling noise when spinning
first check to make is to be sure machine is level using a 2ft level ck level side to side and front to rear see if level if not adjust either by adjusting level legs on bottom of machine or using wooden door shims available @ building supply store , if you don't have level use two small clear water glasses with a exact amount of water in each put a line on each glass measure with rule and make sure line is in exactly same spot on each glass fill to line and place one on rear of machine and one on front level till lines match then repeat process side to side
3helpful
Drain and change oil
I can't tell you all the particulars from the limited amount of pictures of your bike. -Remove the oil drain bolt on the bottom of the crankcase (the universal bolt size for bikes use a 17mm wrench). -Drain the oil (remember to recycle). -Re-install the drain bolt with a new sealing washer if necessary. -The oil fill cap should be some where on the top of the crankcase. About 1 or 25mm in diameter with a raised tab for turning. -Fill with recommended oil. -There are 2 ways to check oil level on dirt bikes: 1) Oil level check bolt. On the right side cover. 2) Oil level site glass. A 1 round piece of glass on the side of the crankcase. Usually by the kick start & R brake lever. -Always check the oil level with the bike upright (as if you were sitting on it). -Check bolt - fill with oil slowly until oil comes out of the check bolt and re-install it. -Sight glass - fill with oil to cover 3/4 of the sight glass. -Remember to hold the bike upright when adding oil.,
Coffee Makers & Espresso Machines Logo
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
Pierre Laplante
Harrie
ADMIN Canada
ADMIN Canada
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
