Question about Lexmark X4270 All-In-One InkJet Printer
3/4" black line on left side of whole page with copying
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 109 Answers
SOURCE: thick black line through page when copying or scanning
Sounds like part of your scanner is not functioning and reading black all the time. Probably best to return it for a replacement.
Steve
Posted on Feb 25, 2009
norman steach
  • 320 Answers
SOURCE: I have a Lexmark Optra T614 and when I print
the problems that you have discribed can all be create by a fuser that is worn. pull the fuser cover which is located in the top cover with a flash light you can inspect the hot roller. from what you have discribed you will find the hotroller to be discolored and every 2 inches or so you will see wear marks from the detack assembly fingers riding on the roller. also the center 3 inches of this roller will brownish colored with lines that will match up to you poor print problem change the fuser and it will fix your problem
Posted on Dec 07, 2009
  • 6073 Answers
SOURCE: When I make copies or transmit a fax, it makes a
The line is probably not from the ink cartridges or nozzles (assuming regular printing doesn't streak). Streaks on copies and transmitted faxes are usually due to dirt or problems on the scanner unit. First clean the flat bed of the scanne. If you have an automatic document feeder, clean that.
Clean with a lint free cloth moistened with a little water or glass cleaner. Make sure no foreign objects are in the ADF path or on the glass. For pictures see the Lexmark support site: http://support.lexmark.com/index?page=product&linkSelected=node0&locale=EN&userlocale=EN_US#1. Then enter "streak on copy" - the solution comes up in a pop up.
If the streak is shrinking, then copy a blank white piece of paper to identify where to clean further. Try scanning another page with a small mark on it. (These are particularly helpful for cleaning the ADF.)
If the mark occurs when you print, then check if you have a damaged cartridge or other ink that has spilled inside the printer.
I hope this helps.
Posted on Feb 02, 2011
Scott Lewis
  • 5 Answers
SOURCE: Just replaced an OEM T632
probable build up on the toner drum or a "sticky" spot on the silver bar on the toner drum, leading to build up of toner at that spot. Take the toner apart and clean.
Posted on Nov 12, 2011
EPSON WORKFORCE 840 AUTO FEED COPIES HAVE BLACK LINE DOWN THE SIDE
Yep. That's what the video shows as well if anyone else needs help. I'm glad you were able to figure that out and resolved it. Simple fix.
Jan 30, 2012 | Epson Office Equipment & Supplies
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Black line down left side of sheet, if i'm copying a page that is and i can't get rid of it no matter what i try i've changed the drum and the toner and still get a line down the whole sheet
If the received fax's are ok and there is no line; and you only get the line when you make a copy....I assume the people you send to are also getting the black line down the page,?? then the problem is in the optics...favorite is some kind of dirt, glue, or corrector fluid on the glass that the original passes over when you make the copy.
Aug 20, 2010 | Office Equipment & Supplies
A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is dirty...open the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Jan 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Thick line when goes throught auto feeder
The automatic feeder passes the page over the scanner, the scanner does move, so even a small mark (often find it is correction fluid) will effect the whole page, check the glass on the left side of the scanner for any sort of mark
Sep 08, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
CopyCentre C20 Black line showing up on the left side of the page
Hello sir; When you make copy is through by ADF? make another copy leave on the glass, compare both, is that same with the line then you have to replace drum blade, if first one with the line and second one without the line, then you need to clean a narrow strip glass on left hand side of the plateform.
Jun 05, 2009 | Xerox CopyCentre C20 Black and White...
Each succeeding copy gets darker and darker
When was the drum replace? Recently? Could it be time again?
Was it a remanufactured unit?
Regardless of all that, It sounds to me like the drum is failing.
Feb 27, 2009 | Brother MFC 4800 All-In-One Laser Printer
Toner banding down the sheets
Need more info.... Is it pitch line accross the page the whole page or banding on the front or back side of the copies or is it black streaks down the page?
Sep 09, 2008 | Canon imageRUNNER 8500 Copier
I have problem while copying with my kyocera mita km-1635
If its on the rear side of the page would most likely to be the transfer unit. What model is the machine?
Thanks Jason
Aug 17, 2008 | Kyocera KM-1510 Copier
Lexmark X4270 All-In-One InkJet Printer Logo
16 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
