Question about Walkera mini cp 6 channel helicopter ready to fly rc
How tight should the blade be
Blade tightness
masud
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 582 Answers
Advanced Technology,The buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music
Posted on May 11, 2017
wwlvictoria
    Renaissance:
  • 1,001 Answers
  • Advanced Technology,The buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music .
  • Protect the earbuds when you during runing and workuots have sweat.Compatible with iPhone 6/6s,6 Plus/6s plus, 5 5c 5s 4s,iPad Air, Samsung Galaxy S6,S5,S4,S3 Note 4 3, HTC M9 M8 M7, LG Flex 2 G3 G2, and Other Bluetooth Android IOS Smart Cell phones/Devices
Robot Check
Posted on Dec 26, 2016
treeeee
    Master:
  • 519 Answers
Bluetooth Headphones V4.1 Wireless Sports Stereo Earbuds with Mic, Noise Cancelling, IPX4 Sweatproof, 8 Hrs Playtime Amazon com YELLWWORSE Bluetooth Headphones V4 1 Wireless Sports Stereo...
Posted on Dec 17, 2016
Skilsaw 3310, motor turns on and runs blade does not. Blade changed and tight on shaft
if the blade is mounted correctly and tight and the motor is running, the only other explanation for a failure is a stripped gear in the gear box
Jan 01, 2017 | Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
Get blade rotor to tighten correctly
1. does the spindle turn freely without the blade attached?
2. is the spindle housing tight against the deck with the mounting bolts tight. If not, check to make sure the housing isnt cracked.
Oct 05, 2014 | Craftsman Garden
How do I put the chain back on the blade
Loosen the screws that hold the blade in place and make it "shorter" by pushing the blade in. Put the chain on it and extend the blade out until it's tight again, but not too tight. It should have a little give to it. Retighten the screws that hold the blade in place.
Apr 10, 2014 | Garden
Blade won't stay tight
if the blade keeps coming loose replace the hub that holds the blade in place
Jun 26, 2012 | Toro Garden
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
Blade wobbling but it is tight
it is probably not a matter of tightness, but the blade is twisted or stuck at an angle on the arbor. Try flipping the blade around and gently slide the blade on and see if it hangs up anywhere. It is possible the blade is bent , but not likely-- also less likely is a bent shaft.
Dec 09, 2009 | Dewalt D24000S Wet Saw With Stand
Can't put on a new blade
start the clippers then slide the blade onto the tongue of the hinge assembly , now push the blade into the clipper don't be afraid sometimes they can be tight from new,
Just make sure the two screws either side of the hinge are tight.
Aug 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
I can't get the blade tight enough
If you tightened it enough and it still slips than it may be missing a spacer Try adding a washer to the arbor of the same size on the nut side of the blade.
Apr 16, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How tight should the blade bolt be on a cut off saw
You've answered this yourself. The blade only needs to be nipped up enough to grip. If it slips, it will tighten. Thats why, some machines have a left hand thread, as they always rotate so as to tighten in the event of slippage.
If the blade slips under normal service, suggest you clean both blade and the flanges, and just do it up a little tighter next time.
Mar 04, 2009 | Ace Hardware Ace Chop Saw Cut - Off Blade
Walkera mini cp 6 channel helicopter ready to fly rc Logo
880 people viewed this question
Top Walkera Clothing Experts
Anon
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Walkera Clothing Expert? Answer questions, earn points and help others
