if those problems were present when you got it back from repair, then, the guy didn't fix it fully.
if those are new problems - then you are now finding out why electronics and plasma displays wear out after ten years, replace the unit, don't pay to 'get it fixed' as the rest of the parts are old and about to also fail.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
hi, As you mentioned its sounds like the X buffer (Right and left) of your tv is faulty. There are two boards in your tv for driving the X plane of the plasma panel. Normally you can find these board on the top or bottom portion of the TV. . Its part numbers are Right buffer board is 6870QSC107A 6871QRH073A and Left buffer board i EAX35683901 EBR35855501. Before purchasing the boards identify which board is faulty. That you can find easily. Check which portion of the screen have vertical line in right or left side of the panel. The board for that side is faulty. You can find these boards on the following link.
If its one large line an inch or two you have a problem with the x boards. If its several thin lines multiple its going to be in your digital/main board.
All plasma an LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
