Question about Ranger Radio Communications
Will not key up on lower channels 26885 older rci
Will not key up on lower channels 26885 older rci 29 50
Posted by deedonovan20 on
Anonymous
    Problem Solver:
  • 10 Answers
The voltage controlled oscillator (VCO) is out of alignment.
Posted on Jun 10, 2009
Would like to know what is the most reliable Galaxy v series, 99 ???, or what is the best opinion of Galaxy in general??
cobra ,is about the easiest to work on and galaxy is good RCI , Midland is secretive , the rest are in the eye of the beholder.
May 03, 2012 | Galaxy Radios DX-99V 40-Channels Base CB...
Rci-2950dx 4 pin microphone wiring schematics
you can't because of the up/down buttons on the mic. the 2950 is a 6 pin and the d-104 is a 4 pin. If you can figure a way to eliminate the u/d switch then go for it. there is a wiring diagram on www.cbtricks.com
Jan 15, 2012 | Midland 1001Z 40-Channels Base CB Radio
Ranger RCI-63FFC4 radio would like to convert it to a standard 40 channel radio
  • Open your radio and look for a board with a plug going nowhere not even plugged in. Plug it in to the back of the frequency display. Some shops will not ship your e-chip because of how easy it is to convert they want to get paid for it.
Regards, Tony
Apr 29, 2011 | Ranger Communications RCI-6900F-25 CB...
2950 RCI WONT TURN ON ONLY A BACKGROUND LIGHT
You either have a bad LCD display OR the connection for the LCD display is loose/off. Its impossible to tell what channel you are on with a 2950 without the screen working, but when you turn the channel knob do you hear any other cb transmitting on ANY channel?? This is a tough one!! I really need some more info on the radio.
Open the case and look at the area that the display is in (front of radio). Slightly wiggle all of the little plugs in that area. If you see the LCD screen come on or flash then you know where your problem lies. If not, then you're probably looking at buying a LCD display for the radio.
Good luck.
Feb 16, 2011 | Ranger RCI-6300F-25 CB Radio
Need operating instructions for RCI-6300F150
You can download and print the operating manual for your 10-meter transceiver here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_om.pdf
In case you need it, you can also download and print the service manual here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_sm.pdf
Bill B.
Oct 25, 2010 | Ranger RCI-6300F-150 Base Scanner
Need cb channel frequencies 1 thu 40
Channel list.
There you will find a list of the citizens band frequencies.
Oct 21, 2009 | Ranger RCI-6900F-25 CB Radio
Need wireing diagram for a rci 2980 to tug8 mic
Here is what I have: If the Tug 8 is a 4 wire cable,1/shield 2/white 3/red 4/black 5/N/C 6/N/C
If the TUG 8 is 6 wire cable,1/shield & blue 2/white 3/red 4/black 5/N/C 6/N/C .The reason I gave two diagrams is I can never remember if the 8 or the 9 is 4 wire cable.Also if your radio keys up when you plug mic in reverse the black and red.Good Luck and take care!
Feb 24, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Rci 2950 reception problem
Mannix, I have not checked skip conditions lately, but the last time I looked skip was not rolling at all so I'd be surprised to hear any australia,,,,,, Mechanic
Oct 18, 2008 | Ranger Communications RCI-6900F-25 CB...
RCI 2950
Hello, Just offhand I'd say you have a bad solder joint on the main circuit board. Without more info, I can not tell you where to look,,,,, Mechanic
Jul 09, 2008 | Ranger Communications RCI-6900F-25 CB...
Radio Communications Logo
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
