These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes and details about many popular brand TVs are given.
SOURCE: Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
SOURCE: blue power light blinking 3 times
I am having the same problem, what was the solution to this problem? And how much did it cost to fix it?
SOURCE: MY 50 inch Hitachi TV wont turn on and the on/off
Unfortunately, this indicates a technical fault with the TV which can only be fixed by a service engineer.
If the light is blue and blinks 3 times, it is indicating a fault with one (or both) of 2 circuit boards inside. They are the XSUS or YSUS boards and will possibly need replacing.
At least knowing this might help you ascertain a quote as too how much the repair will cost.
