My memo pad frozen when trying to connect to my wifi, the screen hasn't changed nor the time. ive tried pushing buttons, the power button and other ones and nothing happens. ive tried plugging it into the charger and again, nothing
Assuming the restart option isn't available after pressing and holding the start button for a few seconds; you can let the battery drain ... but it may take a few hours. (Adapter must be unplugged). Then connect the adapter and restart. Another way is to remove the battery.
After the tab restarts check if system updates are taken care of. If the problem happens because of a particular app consider to uninstall that app.
The issue isn't with the tablet, it is something in your Wifi...there are a number of things that it could be, try simply rebooting your router, that would be the easiest thing to try. If that doesn't work, try switching your tablet to "airplane mode" , and then try to connect...
To restart, press and hold the on button on the upper right of the device. Select 'Restart' from pop-up menu.
Not sure if you can recalibrate your screen.
If all else fails, perhaps you can try hard reset: http://hard-resets.com/hard-reset-asus-memo-pad-hd7/
Try if you can avoid wiping data by selecting option not to wipe.
Check your wifi card at a site where you are sure there is a good connetivity. If works, it's your connections. If you have problem, it's your wireless card
FINALLY RESET REQUIRED FOR THE TABLET, JUST PUSH THE RESET BUTTON ADAJACENT TO THE VOLUME BUTTON, WHICH WILL LOOK LIKE A PIN HOLE. INSERT AN JUMP CLIP FIRMLY BY STRAINGING IT AND WAIT FOR 10 - 15 SECONDS TO MASTER RESET. THEN ENJOY....
ASUS Miracast Dongle lets you experience Full HD wireless entertainment and lets you stream your favorite movies, videos and photos through to any compatible large screen TV. Easy to set up and play, Miracast Dongle supports dual-band wireless (2.4GHz and 5GHz) and HDMI to ensure no latency in signal transmission.
Compatible Model ASUS MeMO Pad HD 7/ME173X
ASUS MeMO Pad FHD 10/ME302C
ASUS MeMO Pad FHD 10 LTE/ME302KL
Nexus 7 (2013)/ME571K/KL
ASUS Transformer Pad/TF701T TF103C
ASUS Fonepad 7 /ME372CG
ASUS MeMO Pad 10/ME102A
ASUS MeMO Pad 8/ME180A ME181C ME181CX
ASUS MeMo Pad 7/ME170C ME176C ME176CX
ASUS Fonepad Note6/ME560CG
ASUS FonePad 7/FE170CG
ASUS FonePad Pad 7 Dual SIM/ME175CG
ASUS The new Padfone Infinity/A86
ASUS VivoTab Note8/M80TA
ASUS Transformer Book/T100
ZenFone/A400CG A450CG A500CG A501CG A500KL A600CG
PadFone mini/PF400CG
Padfone S/PF500KL
It not power on or it have a paswoard problem ? if is paswoard remove it with yoo pc and this program mobogenie instal it in you pc then conect and instal you memo pad in the pc then go to folders ask the paawoard archive edit it and ready clear all paswoard in to you memo pad vote please
