SOURCE: Bernina 1630
I have a Bernina Virtuosa so not the same machine - but this may help. There is an icon on the front of the machine - it is a needlepoint pointing at a dot in an oval - there are arrow buttons on either side. These move the needle left or right of center and it shows on LED screen. I checked mine just now and if you turn machine off and on it resets to center automatically. Hope this helps - Happy Sewing!!
SOURCE: Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
SOURCE: Bernina 1630 needle will not move go side to side.
If you can pull the needle bar down manually and it springs back up, the basting clutch is stuck. By someone who knows how, it's a very easy fix. I would guide you here, but I don't know how to explain it. Plus, you have to be very careful not to damage the spring loaded clutch.
SOURCE: Can someone show me how
you can download a manual from here.
http://safemanuals.com/user-guide-instructions-owner-manual/BERNINA/1630%20INSPIRATION%20PLUS-_E
SOURCE: I have a bernina 1630.
yes, it's very possible, only a repair shop tech can tell you for sure
Yes, on the upper front of the right side there is a ridged little wheel which controls the LCD screen brightness. Use the cap end of the little screwdriver to turn the wheel (the tool which you use to loosen the needle screw.)
