Question about Panasonic KX TGA270S Cordless Expansion Handset
Reset phone i have a set of panasonic kxtga270s phones. the base is working but one of the auxilary phones will not chage. the base of that phone is reading a red light that indicates it is charging but the handset will not charge. should i change the battery?
Posted by nsw1 on
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: charging
A good trick to ensure a good connection for a cordless phone to it's base is to clean the silver connection points with a pencil eraser.
Posted on Mar 29, 2007
Bird713
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
Anonymous
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
Anonymous
  • 813 Answers
SOURCE: Panasonic KX-TG6700
hi friend
chk your hand set it anyware tochiing it so it can fit in that box
or chk with a good phone reapairer
Posted on Apr 13, 2008
Anonymous
SOURCE: Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Posted on Mar 23, 2009
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
We bought a Panasonic Cordless phone model # KX-TG6441 last December. We went out of town recently and when we returned if someone calls the machine says that the mailbox has not been set up. It worked...
Hi,i think the phone needs a master reset in order to reset all the internal settings which might have frozen up as a result of not being used over a period of time,
so the solution is to reset the base and the phone to restore the phone back to a normal working condition.
Thanks and take care
Jun 08, 2010 | Panasonic Cell Phones
Want to be able to lift panasonic kxtga270s cordless phone off
press the function button (lower left) arrow down to i"Initial Settings" , arrow right, arrow down to "Auto Talk" arrow down to "off" press "Save"
Aug 29, 2009 | Panasonic KX TGA270S Cordless Expansion...
Panasonic KX TG9331 no link to base Even standing next to the base, I cannot answer the call. Sometimes repeated pressing of the talk button lets me talk. Also, switching to speaker phone sometimes drops...
Sounds like a defective handset or base unit. Unplug the base unit from power and the telephone jack. Leave unplugged for 1 minute, this sometimes helps the phone to reset from a problem. Unplug the battery from the handset and plug back in after a minute also to help reset. Place your handset in the base unit for about 1 minute to allow the handset to link up with the base unit. If this doesn't work you may have a defective phone. Contact Panasonic support for further information if this does not work.
Aug 29, 2009 | Panasonic KX-TG9331T Cordless Phone
I have a 3 set of the above system KX-TG1033S. No dial tone
Try power cycle , or Reset base ,from handset menu . Check it out if there is reset menu in menu/setting /reset ...simular like that .
Feb 21, 2009 | Panasonic KX-TG1033S Cordless Phone
I have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
Feb 04, 2009 | Panasonic KX-TG1033S Cordless Phone
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX TGA270S Cordless Expansion Handset Logo
55 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
