Fire Lite cannot access the information stored in the firelite smart disk hard drive
SOURCE: firelite smartdisk
sounds like the firewire drivers are corrupt try and re-install drivers and if that did'nt help take drive to a friends house that has firewire on his computer and try on his if you get the same it's got to be sent off to be repaired and hopefully you can get files back thats why i take 2 copys one on one hdd and another on another and if one goes down I've got a back-up to fall back
SOURCE: ACER SMART failure
SMART means self monitoring and reporting tool, this is the option which performs certain test for the status of hard disk health, if its coming it means condition of your hard disk is not good, its better if you immediately back up your data and replace it, by the way you can also disable this warning through the bios, just disable the smart feature in hard disk
SOURCE: Seagate 100GB Hard Drive for notebook SMART failure
Solution #1 is grossly incorrect. The S.M.A.R.T. mechanism is software/application/drive content agnostic. It is a firmware-based predictive failure feature. If the S.M.A.R.T. test returns a certain bit, then the drive is degrading and in need of replacement. If the disk is under warranty, then it generally qualifies for free replacement. If it is not under warranty, then you can run diagnostics such as http://www.santools.com/smart/unix/manual which can sometimes identify the specifics. Sometimes the problem is transient, like the disk was powered on/off too many times in a short amount of time, or the temperature is too high.
SOURCE: smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
SOURCE: smart failure predicted on hard disk 4
Yes usually that error means that the hard drive is telling the controller card that there are some problems with the drive.
Although the drive may still work, it is highly recommended to replace it with a new drive.
I would replace the drive but keep the old drive just in case, after re-installing Vista you find that there is additional data you did not backup or remember to backup.
Just replace the drive, and if it's a Dell laptop, use the Dell Vista reinstallation DVD, and it will not ask for a keycode to reinstall.
May also want to go to another computer and go to support.dell.com and click Drivers and Downloads. Type the service tag and go ahead and download all drivers needed (i.e. network card, sound card, etc.) so after you reinstall Vista, if there are any drivers missing you will be ready to install them.
Hope this helps.
