Ricoh FAX3900NF Plain Paper Laser Logo
Izzy Holymoly Posted on Feb 03, 2014
Fax machine manual - Ricoh FAX3900NF Plain Paper Laser
Have answering machine and fax on same line. How do I receive calls or faxes?
Your fax machine *may* have specific instructions (if not too old) for this very common type of installation (many do). Consult your fax manual to learn how to set this up. Your AT&T TL86109 phone has no options for adding a fax machine.
If your fax machine lacks the built-in ability to forward non-fax calls to your telephone or TAD, you will need to either purchase a fax machine that can do this, purchase and install a "fax switch" or, manage your fax calls manually - by only enabling the fax machine to answer calls when a fax is expected.
If yout still have problems, please post the name / model of your FAX machine. I hope this helps & good luck!
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
2answers
How to hookup afax machine?
You can download a copy of the manual at
http://www.devicemanuals.com/guidedownload/Brother-FAX-575-Thermal-Transfer-FAX-Machine-User-Manual-T0RFMk1qVT.html
Printer busy
sounds like the faxes are stuck in memory
look in the Troubleshooting section of the manual
http://www.retrevo.com/support/Brother-FAX-4100-Fax-Machines-manual/id/386bh847/t/2/
1helpful
Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
4helpful
2answers
User manual for Fax-B840
Dear Harwoodian,
You can download the User Manual for you fax from this URL:
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=Faxes&series=Personal+BubbleJet+Faxes&model=FAX-B840&menu=Manual
Cheerup and Be Happy Always
1helpful
2answers
Brothers 2800
The machine is probably set to "manual receive." Check the receive mode. In "Manual" mode the machine will ring until the start" button is pressed. Fax mode will allow the machine to receive faxes as will the "Auto" mode which will allow both faxes and telephone calls automatically.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
