Fryer is less than two weeks old
SOURCE: Pitco sg 18 s lpg
my friend it looks as if you have a leaking frypot. Do not use this fryer untill the frypot is replaced it is dangerous to use in this condition.
SOURCE: flames in the exhaust of my american range deef fryer
Oil leaking into combustion area... needs ne pot. Might be under warranty...call factory with serial #
SOURCE: our commercial pitco fryer shooting flames
check burners and chambers for soot build up. Check gas regulator valve
SOURCE: flame not going into heat tubes
Make sure the regulator assembly on the gas valve is for propane. Sounds like the gas pressure is too low and the flames aren't going into the burner tubes. Make sure they didn't install an appliance regulator on the back of the fryer. This is not needed as the fryer has a regulator on the gas valve. You can unscrew the cap on the regulator assembly and turn the plastic screw inside all the way in. DO not turn with alot of force. Easy does it.
Tom
SOURCE: My Pitco fryer is shooting
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
