Question about HP LaserJet P3005 Printer
I can not power on my hp laserjet p3005 printer
Posted by patrick jenkins on
Lars-Eirik
  • 65 Answers
Try plug the powercord in different outlet.
No luck ? Your powersupply i probably defect and needs to be replaced. Contact your local HP repair-shop and have them repairing your product.
Posted on Mar 09, 2014
3 Related Answers
Lars-Eirik
  • 65 Answers
SOURCE: hp laserjet p3005 error message 49.4c02 error
Turn the printer off. Remove any jobs i the printercue. restart, and the printer should be OK.
Posted on Aug 03, 2009
Anonymous
  • 81 Answers
SOURCE: how to replace fuser drive assembly on HP laserjet
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P3005%20Parts,%20Service%20Manual.pdf
Hi, this is a link to the service manual for this printer. It may help you with replacing the part
Posted on Jan 01, 2010
Russ Blakeman
  • 87 Answers
SOURCE: 49.4C02 Error
The P3005 is known to have problems with a chip on the formatter, gives various errors to include the 49.2d9d, blank display and others. HP has not issued a recall or service advisory but is fully aware of failure of the chip on the formatter. Repair for this is to print a configuration page, replace the formatter board, bring the machine back up in service mode and put in the correct serial, service code and page counts into the new formatter's nvram memory.
Liberty Parts Team at lbrty.com has refurbished formatters at reasonable pricing with no return core to worry about. The PIN needed to access the service mode is 10300506.
Other problems with the P3005 are grinding in the fuser area, correctable by removal of the fuser, replacement of the 4 accessable gears in the side (left as you look into the back) and the main gear on the fuser then put the fuser back in and should be good.
Service manual available for free at feedroller.com - down the left navigation bar near the bottom is an icon and link to service manuals in PDF. No need to make someone on ebay rich selling copyrighted pdfs.
Posted on Jun 25, 2010
How to connect hp laserjet p3005 to a network or wifi
Follow this link ,may be it will help you....http://www.hp.com/global/us/en/wireless/printer-setup-help.html
Feb 06, 2013 | HP LaserJet P3005 Printer
Where can I download the latest Firmware upgrade for the HP LaserJet P3005 printer. I am unable to locate it on the HP site
Doesn't look like there is any firmware updates it would be posted on the site you could check if HP Easy Printer Care Software has any options for firmware upgrades.
Mar 18, 2011 | HP LaserJet P3005 Printer
My HP Laserjet P3005 is almost 2 years old and needs a new fuser assembly. Is this normal? How much should this cost? Would I be better off buying a new printer
Hewlett Packard P3005 Fuser
The HP P3005 fuser is located at the back of the printer.
The fuser is suppose to last up to 200,000 pages, however they rarely get that far.
The fuser has a thin film upper roller which can be torn, some symptons can be "Wrinkled Pages","Poor Fusing", "Toner Rubs Off the Page", "Pieces of black Plastic Come Out".
*** The printer should be unplugged from any power source before any servicing is performed ***
The rear cover can be taken off by removing 2 screws. Once the cover has been removed the fuser can be removed by taking out 4 screws and 3 electrical connections.
Part Number and purchasing link below
RM1-3717-020
Dec 07, 2010 | HP LaserJet P3005 Printer
Hp laser jet p3005 printer when switched on it shows no display and it doesnt print also
check ypur power cable or you may have a problem in your formatter board,
Apr 08, 2010 | HP LaserJet P3005 Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
Error message 52.00
HP LaserJet P3005 Printer- just changed toner and now service error displayed, tried to power on/off still not working??
May 14, 2009 | HP LaserJet P3005 Printer
Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Nov 27, 2008 | HP LaserJet P3005 Printer
HP LaserJet P3005 Printer Logo
54 people viewed this question
Ekse
efs_perpends
efs_perpends
