Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
My dnile samsung have shadow on the image, what can I do to get it off
Posted by williams james on
Frank Jaeger
    New Friend:
  • 28 Answers
This appears to be a CRT projection TV, is this affecting all other inputs?
Posted on Feb 06, 2014
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Sep 01, 2014 | Samsung CLP 315 Laser Printer
Samsung vertical shadow screen
Does the screen have a double image? or is one side of the screen darker and has a delay? If so, your LCD panel is failing, common problem with older Samsung LCD's. I have the same model in my dining room that had a double image, fixed it by taking the panel apart and applying thermal pads on top of the panel tabs. The set works like a champ to this day!!!
Oct 27, 2013 | Samsung LN-T4665F 46 in. LCD Television
Images show double images like shadows
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergence board to fix the tv convergence board to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole convergence board for the replacement,might still have it.The DLP tvs AKAI and Samsung tvs used the same convergence board.Or the shop,will cost u like 300-350 for parts and labors.
Dec 17, 2010 | Samsung HCM5525W 55" Rear Projection...
Shows shadow behind every image
try replacing the cable 1st, if that fails it is probably a bad CRT.
Samsung CRTs are notorious for going bad even before their warranty period has expired
Mar 28, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
When we turned on our set, the image has a shadow,
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Samsung HCM4216W 42" Rear Projection...
Samsung 931B monitor - shadowing
I have the same monitor, and twice I've experienced this exact problem. In my case, the video connectors have relaxed. If I wiggle the cable, I can make it better or worse, so it's time to disconnect, reseat. I don't know if it will work for you, but it's free!
Feb 20, 2009 | Samsung 931BF 17" LCD Monitor
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Jul 22, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
Shadowing
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Apr 18, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
