SOURCE: SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
SOURCE: my seagate sata 500gb barracuda
If your hard drive is an IDE type, the data cable that connects it to the motherboard will be a flat (usually gray colored) cable that has three 40 pin female connectors on it. If it is an 18" cable, the 2 connectors that go to IDE devices (hard drive or CD-ROM) will be spaced about 6" apart at one end of the cable and the connector that connects to the motherboard will be at the far end of the cable. Also, the cable will have a red stripe along one side of it. The stripe is an indicator of where pin # 1 is on the cable.
Since the IDE cable connects to two devices, there has to be a way for the motherboard controller to know what is connected to each connector. This is accomplished by small straps called jumpers on the rear of the IDE devices. The jumper choices are Cable Select (CS), Master (MA), and Slave (SL).
If your hard drive is strapped as master you must connect it to the connector at the end of the cable. ( If there is a second device on the cable it must be strapped as slave.)
If your hard drive is strapped as Cable Select it is usually connected to the end of the cable but any device on the 2nd connector must also be strapped as Cable Select.
Verify that the hard drive is strapped properly and then be sure it is connected to the drive with the red stripe side closest to the hard drive 4 pin power connector.
At the motherboard end, be sure the cable is connected with the red stripe side adjacent to pin 1. A "!" is usually marked on the motherboard next to the pin 1 of the IDE socket.
Verify that a 4 pin power connector is plugged into the connector on your hard drive and be sure it is fully inserted. .
If you have a SATA drive, the connections are easier. Verify that one end of a SATA data cable (usually red in color) is connected to your hard drive and the other to the first available SATA connector on your motherboard.. Then verify that a SATA power cable is connected to the power receptacle on your hard drive.
When you are sure your connections are correct, plug in and as you turn on your PC, hold down the delete key to enter BIOS setup. (On some machines it's the F!, F2 or F10 key).
Once in BIOS setup, first scroll through all the menus and make sure that all on-board IDE and SATA devices show that they are set for ENABLED or Auto (If you see DISABLED, change it to ENABLED.)
Then, press the Enter key to select the first display screen, ususally titled "Standard CMOS Features". Your Hard Drive should be listed under IDE or Sata devices. If it is, follow the on-screen instructions to get to the Boot Menu. If this hard drive is the device that you want to load your operating system from, be sure it is listed as one of the boot choices.
If the CMOS does not see your hard drive, then you need to have the drive and your PC tested by a PC technician to determine what the problem is.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
SOURCE: Barracuda (ST380215A) 80 GB IDE
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
SOURCE: i`m unable to install windows
How do you format a hard drive that has Windows Vista on it? I cannot find MS Dos. Thanks, Sherry ([email protected]).
