Bought Sierra Wireless for travel. Directions said to go to att.elevate and change password. So I changed attadmin to a password of my own. Ever since then my AT&T home Internet dsl 2wire264 won't let my laptop browsers get on the Internet. I can see where laptop is connected to 2642wire but I can't get on Internet at all now with home laptop! Fine print said something about having to change your laptop wife connection manager or something mi can't find out to do that. I can't go to att.elevate from anything as it says server not found. I have held the reset button in on Sierra and it reboots but I don't know how to see if it went back to attadmin , I'm not even sure this is tied into me not being able to get on Internet. Thanks for any help u can give me
SOURCE: Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
SOURCE: how to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
SOURCE: Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
SOURCE: how to change password for Trendnet TEW 432BRD wireless router
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Thanks.
