Question about FUJIFILM Cameras
SOURCE: Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
SOURCE: how do i get my
you can use a cable or docking station that comes with the camera. Attach cable between camera and PC usb jack.
Posted on Oct 13, 2008
SOURCE: Accessing internal pictures from FujiFilm FinePix S700 digital ca
Take the xd card out of the camera and then you can access the internal memory.
Posted on Dec 22, 2008
SOURCE: how to transfer internal images to sd card?
Put memory card in camera, power up, go to menu and find copy option, select it and press ok.
That will copy picture files from internal memory to memory card.
Posted on Jun 17, 2009
SOURCE: Internal Memory is full
Your camera should automatically recognise when a memory card is inserted and store pictures on to that rather than use the internal memory. The internal memory is only used when no card is inserted so possibly there is a fault with the card connections if it does not recognise when it is inserted.
To clear the internal memory have a look at my post on my tips page on my profile dealing with this.
Posted on Jan 18, 2010
Jul 23, 2014 | FujiFilm FinePix S2980 Digital Camera...
Aug 01, 2013 | Fujifilm Finepix S2980
May 16, 2013 | Fujifilm Finepix S2980
Jan 27, 2013 | Fujifilm Finepix S2980
Oct 03, 2012 | Fujifilm Finepix S2980
Aug 13, 2012 | Fujifilm Finepix S2980
Aug 12, 2012 | Fujifilm Finepix S2980
Jun 27, 2012 | Fujifilm Finepix S2980
May 20, 2012 | FUJIFILM Cameras
May 08, 2012 | FujiFilm FinePix S2980 Digital Camera...
80 people viewed this question
