Question about Zebra 105Se Thermal Printer
Zebra 105se usb connecting problem - Zebra 105Se Thermal Printer
5 Related Answers
Anonymous
  • 38 Answers
SOURCE: Need to increase my font on Zebra 105SE
All fonts are controlled by software. You cannot change them throught the front panel.
Steve W
LazerTek, LLC
Posted on Jan 27, 2008
Anonymous
  • 38 Answers
SOURCE: Zebra 105Se
The 105Se does not have a downloadable firmware file.
Sorry.
Posted on Mar 05, 2008
Anonymous
SOURCE: Serial Settings for the Zebra 105Se
here is manual
http://www.jnc-service.nl/assets/manuals/zebra/S-series.pdf
Posted on May 20, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: how to adjust and align the printout downward
Here is a video which shows you how: (should be the same for your printer)
http://www.findinternettv.com/Video,item,554494454.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Mar 03, 2009
Anonymous
  • 5 Answers
SOURCE: Zebra 105Se power on calibration
If this unit has the LCD screen you need to Press Setup. Then Press Next till you get to Media Power Up and set it to FEED. Next go to Head Close and set it to FEED also and then save settings. It will only shoot one label out instead of Calibrate. Which is needed when they install new lables if its the same type of label all the time really don't need to Calibrate every time you stick new labels in it.
Posted on Mar 25, 2009
My Zebra 105Se printer keeps printing blank labels
There are several reasons why this could be happening. If the computer accessing the printer changed then I assume the new computer was recently set up with software to send print information to the printer. I would start with simple calibration and move from there. Zebra Technologies 105SL Printer Calibrating the Printer With Video
Jun 04, 2014 | Zebra 105Se Thermal Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
Zebra 105Se not working
www.clearprintsolutions.com
Oct 12, 2009 | Zebra 105Se Thermal Printer
Zebra 105SE 25 pin serial cable
error can be on the pc.side or the printer's:
check
- if in windows the LPT ports are addressed properly (if u got a many usb ports, then windows adresses these first and skips the older lpt's- same applies when using an external usb-hub/splitter!)
- that there are no dma or irq conflicts
(see device manager)
- if the right driver is installed, if it suits the windows version u are using/has been written for it
- doublecheck printer against another printer
on your pc using same port
- and/or try to connect it to another pc
so u make sure on which side the error ocurs!
least: check the cable itself
Jun 13, 2009 | Zebra 105Se Thermal Printer
Printer printing from PC W/2000 but not with XP
Hi Kmcnew,
This issue could occur if the connections are not proper.
If the printer is connected using USB cable then you need to make sure that the printer is installed on DOT 4 port.
We need to also make sure that the driver for this printer is installed and listed under printers and faxes.
May 14, 2009 | Zebra 105Se Thermal Printer
Driver for Zebra 105se
Hi spydo...
Zebra 105se drivers (xp/vista/win7/win8) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 03, 2009 | Zebra 105Se Thermal Printer
here is manual
Apr 16, 2008 | Zebra 105Se Thermal Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se
Sorry.
Feb 02, 2008 | Zebra 105Se Thermal Printer
Steve W
LazerTek, LLC
Jan 18, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
44 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
