Lenovo G570 Notebook Logo
Joseph Rardin Posted on Feb 03, 2014
Running 2 external displays on a lenovo g570-4334
Can i run more than 1 external vga display using a vga splicer on my lenovo g570 making it a 3 display system?
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
tip
Here is how to connect your Windows 7 installed notebook to an external display
Most of the notebooks that were manufactured in the past two-three years come with a HDMI port along with the old VGA port to connect your computer to an external display. Connecting and activating an external display on a Windows 7 machine is pretty simple.
Here is how to connect your Windows 7 installed notebook to an external display:
1. Connect your Windows 7 laptop to the external display using VGA or HDMI cable.
2. Then, switch on your Windows 7 laptop and also the external display.
3. Once Windows 7 is up and running, type Mobility Center in Start menu search area and hit enter to open the same.
4. If you have connected your Windows 7 machine to the external display properly, you should now see Display connected text under External display section of Windows Mobility Center. To use the connected external display, click Connect Display button. You should now see your Windows 7 desktop in the external display as well.
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays
on Jun 18, 2010 • Computers & Internet
tip
How to connect Laptop to an External Monitor?
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays.
on Jun 14, 2010 • Computers & Internet
Unlock password
How about looking at a screen?
Use an external monitor
Briefly;
Your laptop has an external display device port. (Connector)
I do not know what it is, because you didn't state the laptop manufacturer name, and model number; Elizabeth
It may be a VGA port, or HDMI port, or Mini-HDMI port; or DVI port
http://en.wikipedia.org/wiki/VGA_Connector
(Scroll down for VGA Cable example)
http://en.wikipedia.org/wiki/HDMI
(You can click on any photo, and it will enlarge)
http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Laptop OFF, monitor OFF, connect the external display device to the laptop.
(VGA = Monitor. DVI = Monitor. HDMI, and Mini-HDMI usually = HDTV. They all compromise an external display device)
Turn the monitor/HDTV on.
Turn the laptop on.
By factory default settings, the display should show on the external display device.
IF not;
There are at least 3 display options. For this example I'm going to use a VGA monitor.
(For a VGA monitor you can use a CRT type of monitor. Looks like a small TV. Or you can use a flat LCD screen monitor, if it has a VGA Cable attached)
The basic 3 display options using a VGA monitor are;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time tap once on the Display Toggle-Over key.
Which key is that? Dunno. Laptop manufacturer name, and ......................
It will be one of the F keys at the top. F1 through F12.
The Function key will have a monitor icon on it, and usually an arrow on one side........Or perhaps two monitor icons sitting side by side.
(Empty rectangle is a monitor icon)
Still no display on external display device?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key
[If memory serves for Display Toggle-Over key;
HP = F4
Acer = F5
Toshiba = F5
IBM/Lenovo = F8
Don't write that in stone, however.......]
Once you post the manufacturer name, and model number; then I can guide you step by step.
Post back in a Comment.
Regards,
joecoolvette
My laptop is vga,so i have bought a vga cable,and a converter box with HDMI cable. My samsung series 5 tv will not pick up the laptop. i have tried all the options available but it just says check devices...
Wouldn't it be NICE to know what laptop you are referring to
Oh well...........maybe one day
By factory default settings the display should automatically show in the external VGA monitor. (TV. Whatever)
HOWEVER;
Your laptop has at least 3 display options;
Press, and hold the Fn key down, and at the same time tap once on the Display Toggle-Over key.
Which key is the Display Toggle-Over key?
Dunno. Laptop manufacturer and model number wasn't stated.
(One of the F keys at the top.
Generally;
Acer = F5
HP = F4
Lenovo/IBM = F10
Dell = F8, unless it's Alienware - F6)
Did that? That's how it worked on your friend's TV?
Then your TV is the problem.
Settings I assume. NOT a TV tech.
Regards,
joecoolvette
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
T42p display lights for a couple of minutes through startup then goes dark
But fan still runs, and it sounds like the harddrive is spinning?
Diagnose.
Do you have a VGA monitor available?
You can use a CRT type, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
http://en.wikipedia.org/wiki/VGA_connector
1) Laptop OFF, monitor OFF, connect the VGA monitor cable to the left side of the ThinkPad T42. (DisplayPort)
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default, the display should show on the external VGA monitor.
If not;
There are at least three display options available;
3) External VGA monitor ONLY.
Press, and hold down on the Fn key, and at the same time tap once on the F7 key. The F7 key is the Display Toggle-Over key.
3) Good display on external monitor?
Problem is the video cable, or inside the Display Assembly.
Since the display goes dark after a couple of minutes, I can tell you the problem is the screen Inverter, or Backlight.
(Inside the Display Assembly)
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED's.
(Light Emitting Diode)
The Lenovo ThinkPad T42 series of Notebook PC's, uses a single CCFL for a Backlight,
http://www.screentekinc.com/IBM__ThinkPad__T42-series-laptops-lcd-screens.shtml
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height ]
A screen Inverter converts the power from the laptop, for the LCD screen, and Backlight.
(Older versions of backlighting that used a series of LED's, used a screen Inverter. Newer versions do not. For these replace the LCD screen)
A screen Inverter and an LCD screen are a MATCHED unit. Make sure you get the correct screen Inverter, or LCD screen, when buying.
Primer over.
One example of a screen Inverter for the T42's,
http://battery-adapter.com/product_info.php/products_id/3381/vThinkpad+T42
Pictorial guide for replacing a screen Inverter, in a ThinkPad T42 series of Notebook PC,
http://www.insidemylaptop.com/replace-screen-inverter-in-ibm-thinkpad-t40-t40p-t41-t41p-t42-t42p-laptops/
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Lenovo Support link to the Hardware Maintenance Manual, for the ThinkPad T42 series of Notebook PC's,
(HMM. It is a Service Manual),
http://support.lenovo.com/en_US/guides-and-manuals/default.page?
Click on the bold black subheading -
Hardware maintenance manuals
Then click on the blue -> [+] Click for files
It is a PDF file.
It may take up to 30 seconds before the first page comes up.
For additional questions please post in a Comment.
Regards,
joecoolvette
1helpful
Does Lenovo 3000 Y410 support dual monitors
Yes.
1) Laptop OFF, monitor OFF.
Connect a VGA monitor to the VGA port, on the back of the laptop.
The VGA port is on the right side, as you view the back of the laptop.
This is a basic example of a VGA cable, and a VGA port, (Connector),
NOTE* Color does Not matter.
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
Press, and hold down on the Fn key, and at the same time tap once on the F3 key.
No?
There are at least 3 display options;
Hold the Fn key down, and tap again on the F3 key.
(The Fn key is down at the bottom LEFT corner of the Keyboard.
The F3 key is at the top of the Keyboard.
The F3 key is the Display Toggle-Over key )
Need more information post in a Comment.
Regards,
joecoolvette
Lenovo 3000 n200 0769AMU press power on switch green light on after about 1 sec screen still black no HD light fan running
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard that usually cause this issue. I wrote a tip on how to do the power drain. Try to plug in external monitor on the VGA port and see if you are getting display using external monitor. If you are getting display using external monitor then the problem would be the laptop LCD. If you are getting the same black screen using external monitor then the problem is already the motherboard.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
