My notebook cannot use the keyboard when opening office documents and always display the above problem. already air blow keyboard but still problem exist. need help. keyboard arrow key is OK when entering bios set-up. already redownload the driver but still have problem.
SOURCE: KEYBOARD PROBLEM
Was there any liquids spilled inside the keyboard? You may need to have the keyboard replaced as they start to fail in due time.
SOURCE: My samsung laptop R420, SHIFT
hello
you can use on-screen keyboard
if the problem is to with this on-screen keyboard
then you will know that the problem is not from your pc keyboard
Enter here to see how to get on-screen keyboard
SOURCE: Auto shutdown when using the keyboard.
First, please:
What have you already tried?
Please turn computer off for 5 minutes.
Turn back on.
Is the problem still there?
If yes:
Turn PC off
Turn PC back on and, while it is booting, tap the F8 key every other second until a boot mode selection screen appears.
Select SAFE MODE
Does problem still exist?
If yes please return here and let me know
Thanks!
Jimm
F1
F2
F3
F4
F5
Create a New Document
There are several ways to create new documents, open existing documents, and save documents in Word:
You will notice that when you click on the Microsoft Office Button and Click New, you have many choices about the types of documents you can create. If you wish to start from a blank document, click Blank. If you wish to start from a template you can browse through your choices on the left, see the choices on center screen, and preview the selection on the right screen.
Opening an Existing Document
Saving a Document
Renaming Documents
To rename a Word document while using the program:
Working on Multiple Documents
Several documents can be opened simultaneously if you are typing or editing multiple documents at once. All open documents will be listed in the View Tab of the Ribbon when you click on Switch Windows. The current document has a checkmark beside the file name. Select another open document to view it.
Document Views
There are many ways to view a document in Word.
To view a document in different forms, click the document views shortcuts at the bottom of the screen or:
Close a Document
To close a document:
F1
Almost always used as the help key,
almost every program will open the help screen when this key is pressed.
Windows Key + F1 would open the Microsoft
Windows help and support center.
Open the Task Pane.
F2
In Windows commonly used to rename a
highlighted icon or file.
Alt + Ctrl + F2 opens a new document
in Microsoft Word.
Ctrl + F2 displays the print preview
window in Microsoft Word.
F3
Often opens a search feature for many
programs including Microsoft Windows.
Shift + F3 will change the text in
Microsoft Word from upper to lower case or a capital letter at the beginning of
every word.
F4
Open find window.
Repeat the last action performed (Word
2000+)
Alt + F4 will close the program
currently active in Microsoft Windows.
Ctrl + F4 will close the open window
within the current active window in Microsoft Windows.
F5
In all modern Internet browsers
pressing F5 will refresh or reload the page or document window.
Open the find, replace, and go to
Starts a slideshow in PowerPoint.
