Texas Instruments TI30XA Scientific Calculator Logo
A
Anonymous Posted on Feb 03, 2014
How to convert 34 3/4 inces to feet
How to convert 34 3/4 inches to feet on scientific calculator?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Sep 22, 2014
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428194
Points
622693
There are twelve (12) inches to a foot, so divide 34 3/4 by 12.
1 Related Answer
k24674
  • 8093 Answers
  • Posted on Sep 17, 2009
SOURCE: Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
How much area will be covered with 36.78 cubic feet of mulch please answer in feet and inches
How it Works
Stone and Mulch Calculators
As an example, let's use 500 square feet to be mulched at a
3" depth.
  1. First, the depth must be converted to feet. To convert inches to feet, simply divide inches by 12, the number of inches in a foot.
    So for our example: 3 inches divided by 12 equals a 0.25 foot depth.
  2. Now that we have the depth in feet, we can multiply the depth by the area.
    So for our example: 0.25 foot depth times 500 square feet equals 125 cubic feet.
  3. If you are calculating 0.5, 2, or 3, cubic foot bags, simply divide 125 cubic feet by the size of the bag.
    So for our example: if we are using 2 cubic foot bags, we can divide 125 cubic feet by 2 which equals 62.5 bags.
  4. If you are calculating cubic yards, we need to convert 125 cubic feet to cubic yards by dividing by 27. One cubic yard is equal to 27 cubic feet, see the diagram below.
    So for our example: 125 cubic feet divided by 27 equals 4.63 cubic yards.
For Your Information
  • 1 inch equals 0.08333 feet
  • 1.5 inches equals 0.125 feet
  • 2 inc
How to convert inches and feet to square feet and square inches
There are several ways to do this.
We can choose either inches or feet as our base.
Let's do the case in inches.
Let's say the measurements are 5'2" by 2'4".
Step 1 - Convert everything into inches, so multiply the feet by 12 and add the inches. 5'2" becomes 5x12+2 = 62". Similarly, with 2'4" 2x12+4 = 28".
Step 2 - Calculate the area in square inches. 62" x 28" = 1736 square inches.
Step 3 - Convert square inches into square feet by dividing the number of square inches by 144 (12" x 12"). I get 12.06 square feet.
Let do the case in feet using the same measurements.
Step 1 - convert everything into feet. Since there are 12" in a foot, divide the inches by 12 and add to the feet. 5'2" becomes 5 + 2/12 = 5.16'. Similarly, 2'4" becomes 2 + 4/12 = 2.33'.
Step 2 - calculate the area in square feet. 5.16' x 2.33' = 12.02 square feet.
Step 3 - Convert the square feet to square inches by multiplying the answer in square feet by the number of square inches in a square foot (144). Imagine a square 12" by 12". 12.02 square feet x 144 = 1730 square inches.
Note that I have rounded my answers, thus, they are not equal. To avoid this, keep the answer in your calculator and round only at the end.
Any questions, let me know.
Good luck.
Paul
How do I do feet and inches calculations on the Casio FX-115ES Plus? For example, how can I do calculations like 10'-3" + 5'-4" + 11'-11" without having to convert the inches to feet?
You can combine all the feet together 10+5+11=26 feet
Combine all the inches together -3-4-11=-18 inches=-2 ft + 6 inches
26 ft -2ft +6 inches =24 ft +6 in=24.5 ft
You can also multiply each inch -value by 1/12
10-3/12+5-4/12+11-11/12=10+5+11 -(3+4+11)/12=26-18/12, continue
Calculators work to base '10' not base '12', so you'll have to convert. the S.I. unit of measurement is used for calculators which is metres and they are base '10'. The metre was calculated by a french bloke who got the calculation wrong, but they still use it. Feet and inches are better.
Convert feet inches
There are 12 inches in a foot, so to convert feet to inches simply multiply by 12.
2answers
Square feet converted to square metres
Simply square the conversion factor between feet and metres to get the conversion factor between square feet and square metres.
One foot is 0.3048 metres, so squaring that gives one square foot is 0.09290304 square metres.
Convert 216 feeet into meter
You need to remember that 1 inch is exactly equal to 2.54 cm
So 1 foot =12 inches =12*2.54 cm= 30.48 cm = 0.3048 m.
With this value you can convert 216 feet in meters as follows
216 feet =216*0.3048 m= 65.8368 m.
2answers
A window glass 4 ft. 2 in. by 2 ft 10in. find its area. show the figure
Below is calculation of window glass area :
4.167 ft '------------------------------------'- ' ' ' ' 2.833 ft ' ' '------------------------------------'--
Total area = 4.167 ft x 2.833 ft = 11.81 ft2
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
