I receive error code e197 when printing. how do i fix it?
SOURCE: mf8180c error code e 197
I believe a E197 error refers to a power problem relating to the fuser. I would remove any covers to access the fuser, remove it and reseat it and any nearby connectors.
SOURCE: Canon Printed LBP 5200 Error Code E000
This error indicates fuser error, its not heating up.
SOURCE: Canon MF8180c
Issue: ERROR LCD: System Error E197
Solution: Verify/reconnect power cord to fixing assembly
The power cord has been disconnected from the fixing assembly.
Verify/reconnect the power cord to the fixing assembly.
SOURCE: Canon MF6500 Error Code E197
Error
E197 0000 is a Printer engine communication error.
A erroneous comm's error occured between the DC controller PCB and
image processor PCB was detected.
Prnter needs servicing
Check cabling connections on theDC controller PCB and image
processor PCB.
If still same then you have to replace DC controller pcb.
If still fials then you have to replace the image processor pcb.
SOURCE: Canon image Runner 1023
E197 0000 Printer engine communication error
Erroneous communication between the DC controller PCB and
- Check the connectors of the DC controller PCB and image processor PCB.
- Replace the DC controller PCB for normal connection.
- Replace the image processor PCB.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .If not contact the canon service to check the mainboard.
