Question about HP 1040 Plain Paper Inkjet Fax
Hp8600 won't receive faxes - HP 1040 Plain Paper Inkjet Fax
FO-3150-won't auto answer, have to pick up receiver to get faxes
renield, that worked perfect!!! Thanks a million!
Feb 06, 2013 | Sharp Fo-3150
Can't print on transparency film
In order to print on transparency film from a HP8600 all you have to do is load the paper rough side down with the white border going into the tray toward the back of the printer so that you can not see it when you look into the paper tray. The HP 8600 will auto-adjust for the film, that is why you do not have the option to select transparency like you did in the HP 8500
Dec 22, 2012 | HP Officejet Pro 8600 e-All-in-One -...
Brother fax machine MFC 495 CW won't print a received fax
Hello sir; would you try on another phone jack if still have same problem then replace phone wire.
Nov 01, 2012 | Brother MFC-495cw Color Inkjet All-in-One...
Jammed paper in hp8600
No other way except to hinge it open and get a hold of the paper.
Jun 14, 2012 | HP Officejet Pro 8600 e-All-in-One -...
My brother fax 837mcs won't receive faxes
check setings and conection to phone tray other phone in the same out
out let to see if you have signal on it.
May 31, 2012 | Brother Office Equipment & Supplies
MY HP FAXNUMER 640 WON'T RECEIVE FAXS AFTER I REPLACED TONER CARTRIDGE
The two aren`t related, you must have pressed a button that changed the `reception mode` to Manual from either `auto` or `tad`
Apr 04, 2012 | HP 640 Inkjet Fax Machine
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
User ManualDellPrinter&faxfor a a960
Hi Susan,
Please note that your printer cannot receive soft copy faxes,it can only send them.
Click here for the manual downloads in pdf format.
Hope this helps.Thanks!
Nov 07, 2011 | Dell A960 All-In-One InkJet Printer
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
HP 1040 Plain Paper Inkjet Fax Logo
Ekse
Thomas F. Schneider
