The system is displaying F60 and nothing else works. Reading through the posting, some said it is the power supply problem. Does the cable has a breaker in case of a spike?
SOURCE: CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
Solution #2
posted on Feb 09, 2008
jdrrwoods
Rank: Wiz
Rating: 84%, 12 votes
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
SOURCE: WILL A TIME WARBER CABLE REMOTE WORK WITH Panasonic DMR-ES15 DVD Recorder
la seña/ dfl comtol remoto
SOURCE: WHEN I TRY TO USE
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
SOURCE: panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
SOURCE: Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
