Carrier 38CKC036 Air Conditioner Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air conditoner won't go on and receiving E2 message on panel
Air conditioner won't go on and receiving E2 message
airconditioning
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Mar 12, 2014
airconditioning
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
95128
Points
56
E2:loss or corruption of stored dat a.
Air Conditioning Fault Codes
Anonymous
Level 3:
  • Master 614 Answers
  • Posted on Jun 05, 2009
Anonymous
Master
Level 3:
Answers
614
Questions
0
Helped
274708
Points
1717
E2 code is 24 volts loss. Check transformer and control voltage should be 24 volts.
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
1helpful
1helpful
What does the message E2 mean...
Certain codes will appear on the display to indicate various malfunctions of the cooler. E. g. if E2 appears in case the fault of the temperature sensor.
8helpful
E2 error code in samsung split AC
From all Samsung recomendations... if your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced.
If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced.
To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864) any day between 9:00 a.m. and 9:00 p.m. Have the model number and serial number of your air conditioner on hand when you call.
Hope helps.
PORTABLE AIR CONDITONER MODEL#APEOIAJMI-DOES NOT
If you turned this unit on right away after you received it you may haved damaged the compressor. You should always let a rfrigeration or a/c unit sit in its up right position for atleast 12 hrs. before operating, so that pressures and oil can equalize inside the system, unplug the unit and check the wires at the compressor and make sure they are still connected, Good luck.
3helpful
EE problem
It could be the control board. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Error message
Type in haier unit page, then,to Haier-model # or go to http://www.haieramerica.com/techsupport.
Wall air conditoners
as long as the width and length are the same you should have no differeance in cooling unless it is either larger or smaller in tonage.
Coleman TSR RV air conditioner
There should be a solar panel on top of your roof top air conditoner. There is a quick disonnect for the solar panel. If the monitor light illuminates the solar panel is working.
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
