Question about 2wire 2700HG-B Router (2700HGB)
What is my wep - 2wire 2700HG-B Router (2700HGB)
How can I find my WEP key?
Check on the bottom of your router or wifi router or on the side its your security key to hook up the device to your other devices.
A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F. Some examples of WEP keys are:examples below
  • 1A648C9FE2
  • 99D767BAC38EA23B0C0176D15
  • 40- / 64-bit WEP: 10 digit key
  • 104- / 128-bit WEP: 26 digit key
  • 256-bit WEP: 58 digit key
Aug 10, 2012 | HP Computers & Internet
What is a wep key and how do i find it
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. WEP keys are chosen by a network administrator. WEP keys are set on Wi-Fi Routers and other wireless network devices. Matching WEP keys must be set on each device for them to communicate with each other.
Dec 27, 2011 | Computers & Internet
What is the wep key
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F. Some examples of WEP keys are:
  • 1A648C9FE2
WEP keys are chosen by a network administrator. WEP keys are set on Wi-Fi routers, adapters and other wireless network devices. Matching WEP keys must be set on each device for them to communicate with each other. The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
Feb 15, 2011 | Linksys E3000 Wireless Router
I still cant find my wep address!
If its your wireless router, take 1 of 3 approaches:
1) forego the wireless connection and wie your PC to the router, ten log into the
router's system mgmt web page and view your WEP setting.
Use this WEP in your wireless link software.
HOW to reset a wireless router: press in the tiny "button" on the bottom.
This resets your router mgmt password to the default in the manual
and resets WEP security to OFF (the default).
Approach #2) reset your router, returning it to the default state, which
is no WEP protection. then, wirelessly login to your routers network
security web page, and set a WEP. Then use this WEP
Approach #3: reset your router, and leave WEP security disabled.
login wirelessly. WEP denies access to those without your
WEP password, it does not allow others to "see" what you're
doing on the internet (as many believe).
Dec 21, 2010 | Computers & Internet
What is the wep
Wired Equivalent Privacy. It is an older wireless protection standard that has been replaced with WPA and WPA2.
Nov 01, 2010 | Computers & Internet
Informed WEP key is a 10 digit number. could 231408&sid nos. & characters be my WEP key?
A WEP key is a security code used on some Wi-Fi networks.A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F.
WEP keys are chosen by a network administrator, it would have been provided by the Internet Service providers, Hence it can't be as what you stated.
Oct 30, 2010 | Computers & Internet
What is a wep key, and where will i find it, for setting up xbox 360 thanks
WEP stands for Wireless Encryption Protocol and it is the wireless key for your router.
You will need to find the WEP key in your router's administration page and then enter it on your xbox under the system settings then network settings.
Dec 25, 2009 | Video Game Consoles & Games
What is the WEP key
Wired Equivalent Privacy (WEP)
WEP is an older network security method that's still available to support older devices, but it's no longer recommended. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. However, WEP security is relatively easy to crack. f4008eb.jpg
Nov 16, 2009 | NetGear WGR614 Wireless Router
I need wep key westell model 327w
Unfortunately, no one could not provide you any WEP key. WEP is a key that you set to your router so that no one could connect to your wireless network. As an owner of the network, you should know what your network key was.
If you forgot your WEP key, you need to reset the router to factory default, configure it and set a new WEP key.
That is the only way. Thank you!
Nov 02, 2009 | Westell Wirespeed VersaLink...
Wep key for ps3
you will need to obtain your wep key no matter what...you can get it from whoever your router company is (if it is a linksys then call the linksys support number and obtain the key) in most cases thought the wep key is located on the router itself near the bar code. It will be a long number, When you get it and enter it in to the network settings then it should pick up the signal
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
2wire 2700HG-B Router (2700HGB) Logo
23 people viewed this question
Top 2wire Computers & Internet Experts
efs_perpends
efs_perpends
Ron Stone
Mike
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
