Question about Mpio Audio Players & Recorders
Hi, I can no longer browse through the files of my MPIO MG 100.
I have an MPIO MG 100 MP3-player. My computer -and any other for that matter- always recognized it as a folder; whenever I double-clicked on it, it showed a list with suggestions of programs I might use to open it. Useless, of course. But by browsing folders I was always able to eliminate that problem and found access to my music files.
Today, after 23 months, the device finally decided to install the driver. OK. So, I let it happen and restarted my computer. My laptop immediately recognized my player as an external device. But now I can no longer browse through the files already stored on my player! My computer says there ARE no files on it! Neither can I format the device and I am also unable to find the driver, in order to delete it and get everything back the way it was!
What must I do?!
Please help a desperate 22-year old!
Posted by fschouten86 on
Anonymous
Ok what charge setting is it on? if its on the MTP setting hold the "MENU" down until a message apears that says "reconnect the mg100 to change the mode" then it should work. if not then i guess i wasnt verry helpful and im sorry
Posted on Sep 27, 2009
  • Anonymous Sep 27, 2009
    i meant to say MSC insteat of MTP sorry
I cant seem to fine out how to charge my mpio
do you have your USB cable? keep it connected to your computer that helps you to transfer files and charge it. device ill tell you when it's fully charged actually there is no charger for it.
if you need to read about it here is a link:
http://www.mpio.com/product/productview_fl350.html
if it works for you don't forget to rate me
thx
Apr 29, 2010 | Mpio FL300 MP3 Player
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
http://www.mpio.com/downloads/index.php
Feb 29, 2008 | Mpio HD-300 MP3 Player
How can i delete files wuthout the software?
MPIO Utility can be used with MPIO player that supports USB Mass Storage.
With this, you can..
- Format and Recover MPIO player
- Upgrade firmware of MPIO flash-type player
- Building playlist of MPIO hdd-type player
* Supported OS : Windows 98 SE, ME, 2000, and XP
* MPIO Utility doesn't work with FL200 and FY300.
* If you are using the latest firmware, be sure to use the latest version of MPIO Utility.
* Please uninstall the old version of MPIO Utility before installation.
[Download]DOWNLOAD NEW DRIVERS AFTER UNINSTALLING OLD ONE'S RICHARDM69
Dec 04, 2008 | Mpio FL400 MP3 Player
Hi, i dont have the disc that comes wuth tho mpio. how can i delete files that i recorded on it?
[Download] REDOWNLOAD NEW DRIVERS AFTER UNINSTALLING OLD ONE'S RICHARDM69
Help !!!!!
The VP-02 is based on the MPIO FL-100. You can get the MPIO manager software from www.MPIO.com. The latest version is MPIO manager version 2 buils 1.8.0.0
Jan 06, 2008 | Virgin Pulse VP-02 MP3 Player
Mp3 player repair
Hi
It's called the FPC cable, you can try to connect Mpio America
[email protected]
Sep 24, 2007 | Mpio HD-300 MP3 Player
Mpio fg200
Turn off the unit and connect it to the computer.
The computer should recognize the player.
Run a program called Mpio Utility (Can be found on the CD or Mpio.com)
Select format & Config
That should do the trick.
Or go to www.mympio.com
Feb 01, 2007 | Mpio FG200 MP3 Player
Deep trouble with the memory..
ok you have to format by itself. reset the fl400 by the pinhole then when its off press play and menu at the same time for 10 seconds then press and hold the rec or rew button. after the format, run mpio utility press on setup & conf now you havet it like new
Jan 18, 2007 | Mpio FL400 MP3 Player
No disk to install software
The VP-02 is based on the MPIO FL-100. You can get the MPIO manager software from www.MPIO.com. The latest version is MPIO manager version 2 buils 1.8.0.0.
Dec 02, 2006 | Virgin Pulse VP-02 MP3 Player
454 people viewed this question
Top Mpio Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
