Question about Harman Kardon SoundSticks II Computer Speakers
Harman Kardon SoundSticks stops after 20 seconds
Sounds great but shuts down after a few seconds
Posted by J Mitchell on
5 Related Answers
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Posted on Dec 30, 2007
hamster47
  • 739 Answers
SOURCE: How can I get my Harman Kardon Soundsticks 1 to work on my PC?
The USB version of the soundsticks was specifically designed for the mac and they worked just by plugging them in and then telling the system to use them instead of the analogue outputs. Unless someone has produced drivers for Windows XP for these speakers I think that you will probably not be able to use them.
Posted on Sep 29, 2009
Anonymous
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
Anonymous
SOURCE: HARMAN/KARDON SOUNDSTICKS 2 NO SOUND
I MISSED THE VOLUME CONTROL ON THE RIGHT SPEAKER. NOT OBVIOUS FROM VOLUME. THE SOLUTION FOR ME. THANKS.
Posted on Jan 01, 2010
hamster47
  • 739 Answers
SOURCE: My Harman Kardon Soundsticks 2
Ok, let's see if we can work this out. You say the speakers are at 100. Where are you seeing this 100? You say the speakers are NOT muted. Where are they NOT muted?
Is the light on in the sub-woofer? Is the volume turned up on the right hand speaker?
Plwase answere these and then we'll see what to do next.
Posted on Feb 06, 2011
Harman Kardon Soundsticks II with subwoofer
Check you volume control center and the likes it may have turned off by itself
I purchased a set of Harman Kardon Soundsticks however they light up but not sound - can you please advise how best to get these fixed. I tried to get help from apple but they pretty much sent me on my way...
I was just given soundsticks speakers with no instructions, and had the same problem. On the right speaker are two buttons marked + and -. Pressing the + button raised the sound level from none to full volume. In my case it was an operator problem.
My harman kardon soundsticks base light flickers, no sound
Ok this needs careful observation to determine this type of problem
Please unplug these speakers and plug it into an mp3 player and write back to me if the speakers work ok? I'll tell you more from there
I have a Harman Kardon SoundSticks (the orgiginal
yes it can....try to search in the internet what converter you will need...
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
No Sound on Harman kardon soundsticks 2
Ok Dave Go to your Start Menu Next Control Menu,Find audio and devices,Click on it,Go to Hardware Tab Click on it,Then at the botton is Properties Click on it.Find the Drivers tab,And then go down to Uninstall,Reboot and let windows reinstall driver,Make sure you are plugged in the Right port and Power for spkrs is Plugged in...
Harman Kardon SoundSticks II Computer Speakers Logo
Top Harman Kardon Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
